Novarossi P5XL Pipe Reccomendation >
Like Tree1Likes
Old 10-13-2013, 01:30 PM
Default Novarossi P5XL Pipe Reccomendation
Hey All,
Looking for a good tuned pipe for a P5XL. Looking for something with probably a fair amount of bottom end and mid range, not as concerned with the top end with the type of track I run on.
Any input would be appreciated.
Thanks,
little_006 is offline
Old 10-13-2013, 02:52 PM
Trader Rating: 68 (100%+)
Originally Posted by little_006 View Post
Hey All,
Thanks,
I'm using the Losi RE12. Affordable and tough. Runs great with good mileage. Everything I need and then some.
Greg B is offline
Old 10-13-2013, 03:23 PM
pickle311's Avatar
Trader Rating: 31 (100%+)
Nova 2084 is a great pipe, the new 2096 is supposed to be better but I haven't tried it. 9901 works pretty good too, it will soften the bottom end a touch and smooth things out.
pickle311 is offline
Old 10-13-2013, 03:47 PM
houston's Avatar
Trader Rating: 96 (100%+)
i would recommend the 9901ss/41021 or that re12
if you want a more balanced feel with amazzzzzing runtimes then 2096/41021
houston is offline
Old 10-13-2013, 05:24 PM
tony montana's Avatar
Trader Rating: 73 (100%+)
love the 2096 and 41021. May call me crazy but I could not get the power I wanted withthe 9901 and 41021
tony montana is offline
Old 10-13-2013, 06:00 PM
Thanks for the input guys, appreciated. I will do some online hunting for some of those pipes. Might get a few just to try em out.
Old 10-13-2013, 06:17 PM
merdith6's Avatar
Default 9853
9853ss
merdith6 is offline
Old 10-13-2013, 07:00 PM
houston's Avatar
9853ss/41021 xlnt truck combo 9853ss/41001 or 41019 or 41005 great for buggy if you REALLLLY like lots o bottom
DXPinoyRC likes this.
houston is offline
Old 10-13-2013, 09:40 PM
xyzyx00's Avatar
theres tons of info, just search titles only for P5xlt (been there done that)
I just changed from the werks 2058 to a nova 9901 with a 41029 manifold (which is the same as the 41021 with a tighter bend for mugen).
2058 had insane top end, the thing friggen screamed but i wasnt happy with the bottom end.
switched over, without adjusting tune, bottom end was snappier, noticably easier clearing jumps out of tight corners. top end was a bit rich. leaned out the hsn about 2-3hrs and l was very happy. things still got plenty of smoke running about 235ish. byrons race 30%/9%
xyzyx00 is offline
Old 10-13-2013, 09:49 PM
xyzyx00's Avatar
im a bit confused from your post... ive read (not tested) and have in my notes that 41001 is for bottom end, 41019 for top end... for my knowledge, am i mistaken? and what about the 41005?
thanks
xyzyx00 is offline
Old 10-13-2013, 10:47 PM
houston's Avatar
thanks
Those are the three different double bend headers which change the running characteristics of the engine and pipe
houston is offline
Old 10-13-2013, 11:23 PM
xyzyx00's Avatar
i undertand the mechanics, I was just trying the verify the performance characteristics of the stated manifolds, high end, low end ect...
xyzyx00 is offline
Old 10-14-2013, 12:15 PM
tlr re12 great all around pipe. and you cant beat the price.
want to make is scream. slap a 2013 or 2058 on it. makes it respond like a light switch.
Gsnow39 is offline
Old 10-14-2013, 12:42 PM
tom1974's Avatar
Hey All,
Thanks,
9901 with long tube!
41020
if you use btt use 9901 or 2096
2096 + long engine
9901 + short engine
tom1974 is offline
Old 10-14-2013, 02:28 PM
houston's Avatar
Shorter headers will provide more upper rpm and sometimes get the "on the pipe" feel quicker bug when put under a load at low rpm will fall flat
longer headers opposite , this is just a basic guideline for pipe tuning , when you have tried and tested so many combos you can see what each engine responds to in particular
houston is offline
