clutch not in place >
clutch not in place
clutch not in place
Old 10-10-2013, 10:00 PM
Default clutch not in place
The clutch of my rc car does not aline properly with the centre gear. The centre gear will aline with half of the clutch. I am worried if i keep driving my car the clutch and centre gear will strip. I have tried moving the engine so it is aline but it is right on the edge. Is there anything i can do or does this not matter
dazablue is offline
Old 10-10-2013, 11:12 PM
Jaz240's Avatar
Trader Rating: 52 (100%+)
You have to shim your clutch. If your flywheel is too far from the engine you have the wrong collet. What clutch and car do you have?
Jaz240 is offline
Old 10-13-2013, 07:54 PM
It is a hip trophy 4.6 with a k4.6 engine, 13t clutch. I have tried other clutches and it happens to all of them
dazablue is offline
Old 10-13-2013, 09:57 PM
Jaz240's Avatar
Sounds like you just have the wrong clutch bell then. Some bells have a much lower or taller profile than others. Check your manual for the correct part number for the clutch bell and get that one.
Jaz240 is offline
Old 10-16-2013, 12:20 AM
that is the clutch in the manual
dazablue is offline
Old 10-16-2013, 06:26 AM
BillyT.'s Avatar
A losi clutchbell will fix this problem...
BUT...
Isn't this a RTR truck? Has it always been this way? Or only after you took it apart?
BillyT. is offline
Old 10-16-2013, 06:02 PM
It has got a k4.6 engine on and the original engine is the f4.6 and i only released it when i posted this thread
dazablue is offline
