Like Tree4Likes
Mugen MBX7T
Old 09-23-2018, 11:00 PM
  #931
Thanks mate
MadMick is offline
Old 09-23-2018, 11:05 PM
  #932
A or c there two types
MadMick is offline
Old 09-24-2018, 06:41 AM
  #933
Both work.
Cardiak is offline
Old 09-25-2018, 11:46 PM
  #934
Hey man did u try it and if not to much off a ask can you show photo what Gos were
MadMick is offline
Old 09-27-2018, 04:28 AM
  #935
So I can order them parts all good
MadMick is offline
Old 09-27-2018, 07:56 AM
  #936
The parts are almost identical to the Mugen ones. The ball studs and shock ends are just thinner to be able to fit into the Sworkz arms. These arms are much stronger. I sent it about 13 feet in the air and landed with no tweaks or anything to the arms.
Cardiak is offline
Old 09-27-2018, 04:32 PM
  #937
you got photo how they fit and all
MadMick is offline
Old 09-27-2018, 04:58 PM
  #938
so all I need theses parts right
SWX-2501121A
SWX-330136A
SWX-330134A
SWX-2502037A
SWX-2502038A
MadMick is offline
Old 04-22-2019, 03:59 PM
  #939
cloud9graffix's Avatar
Is the 7t and the 7tr chassis the same?
cloud9graffix is offline
Old 04-22-2019, 04:17 PM
  #940
Nvm
Cardiak is offline
Old 04-22-2019, 04:20 PM
  #941
Adam Drake's Avatar
The side bends are more on the 7TR chassis, but they're the same other then that.
Adam Drake is offline
Old 04-23-2019, 04:25 PM
  #942
Great. I can not find a new 7tr chassis but many new 7t ones to be had
Old 05-17-2019, 09:50 AM
  #943
Default Mbx7T chassis braces
Do they make the aluminum chassis braces for the Mbx7T? I haven't been able to find them. I cut a groove into an old mbx5 front mount and it fit in the truggy but if they make the correct ones I'd rather change it and replace the rear one. Or I saw a pair for an RC8T3.1 and was wondering if anymore tried to use them in the Mugen. We used to cross brand all the time back in the day when other parts were better from other brands.
Mbx4man is offline
Old 05-22-2019, 04:12 AM
  #944
1/8 IC Fan's Avatar
Trader Rating: 91 (100%+)
Just run the stock ones, aluminum is not needed, the Composite ones will give under load and dampen the flex, vs running aluminum ones that will lead to a bend or tweaked chassis. The new Truggies have come along way,
1/8 IC Fan is offline
Old 05-28-2019, 08:15 PM
  #945
I might just put the stock front back in then. Thank you.
Mbx4man is offline
