-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   NEED HELP PLEASE!!! (https://www.rctech.net/forum/nitro-off-road/740650-need-help-please.html)
dylank555 06-28-2013 05:51 AM
NEED HELP PLEASE!!!
1 Attachment(s)
hello fellow people
i am currently cleaning my buggy, and i found a grub screw that had come loose on this part(open attachment) and was wondering first of all what the part is called?
and secondly any ideas on how to take it apart to get the screw out?
if you can help i would highly appreciate it THANKYOU!!!!:nod:
Roelof 06-28-2013 06:01 AM
That is called an outdrive. Through the hole you can see the shaft which has a flat spot. Turn the frontwheels until the flat spot is shown and screw it.
ozziii 06-28-2013 06:06 AM
The grub screw stops the outdrive spinning on the pinion shaft coming out of the diff housing, when you put the grub back in use blue (medium) threadlock so it stays there.
masher81 06-28-2013 06:08 AM
The problem is you will need to remove the rear diff and hold the pinon in place to make sure when you tighten down the grub screw the mesh between the pinion and ring gear is correct.
dylank555 06-28-2013 06:09 AM
thanks for the help :) :)
