Throttle hand going numb
I'm everyone will have fun with this one. After about 5 min my throttle hand will start to lose feeling in my throttle hand and can't feel the trigger any more. Anyone else have this experience what did you do to combat the problem?
I had this problem when I started in the 90's. My trick was to start loosening my grip (not hold it as tight). That worked until the Arizona summers, then the sweat would get in there and make it kind of slick. So then a fellow racer sold me on the idea of putting a tennis racket grip tape on it. After a few attempts to make it "feel" right, I have been running it ever since.
After I broke my wrist I had this problem. My doctor told me that blood flow is worse to my hand due to my injury, and since there are blood vessels in the palm of the hand, holding the transmitter blocks even more blood from flowing to the fingers, causing my hand to go numb.
So she told me to increase the size of the grip so that there is a larger surface touching my hand. I did that and haven't had problems since. I just use grip tape.
I would go and get a carpal tunnel test. I had the same problem and i got tested. It tested pretty bad but after the surgery I can go an hour main with no issues. I would say for about 2 weeks I had a soft cast on then was driving right after. It was sore for a couple months until it healed up but its dialed now!
Practice on radio posture, keep your wrist straight with no kinks and hold the radio with a nice relaxed grip. Try different grip thicknesses also to see if that helps.
I cant say i ever had that issue lol . Now loosing grip holding the radio when my hands sweat yes and my hands shaking if im leading a race sure.
Using the throttle trigger never had my fingers cramp but than again im running Electric maybe thats why.
R/C Tech Elite Member
that's why you see a lot a drivers with their arms down driving by their belt, it really helps
Yea, not that I'm super fast in off road or anything but I work for an rc company and I have to make our product look respectable. It was a problem in long nitro on road mains also. If 10 minutes into a main I can't feel where my trigger is, it not very easy to get around. Not only that but if you let it keep happening your just ruining your nerves and can lead to permanent damage.
I wrap it with grip tape for tennis rackets. This makes the grip a little bigger (better imo) and it absorbs sweat.
