kyosho rides on his own >
Old 05-25-2013, 01:53 PM
NewbieToNitro's Avatar
Default kyosho rides on his own
Hello I bought a pure ten alpha second hand and I'm new to nitro and I've a problem.
When I start it (which was a problem as well because of bad maintanence of the previous owner) it is riding on is own, what is the problem?
NewbieToNitro is offline
Old 05-25-2013, 04:58 PM
Fanatiq's Avatar
Might be your idle/tune or bad clutch springs/bearings or both :O I'd start from there
Fanatiq is offline
Old 05-25-2013, 06:44 PM
jmackani's Avatar
Trader Rating: 14 (100%+)
The drive train on a kyosho is so free that this is normal when on the starter box.
jmackani is offline
Old 05-25-2013, 09:08 PM
H0LESH0T's Avatar
Is the car just slowly running while on starting box? Does it run when on ground?
H0LESH0T is offline
Old 05-26-2013, 03:04 AM
ozziii's Avatar
If its just sitting on the starter box idling then the wheels shouldn't be turning, no matter what car or how free running the driveline is. The clutch would have to be engaging or bad bearings binding & causing clutchbell to spin on the crank shaft, if engine is idling low enough then this shouldn't happen if clutch is all good.
Pull the clutch bell off & replace bearings & clutch springs & make sure clutch shoes are good & not binding on flywheel posts.
ozziii is offline
Old 05-26-2013, 03:13 AM
I don't have a starterbox it is a pullstart.
When i put my car on the ground it is moving and not just slow.
