Losi 8 1.0 to 2.0 >
Losi 8 1.0 to 2.0
Losi 8 1.0 to 2.0
Old 05-12-2013, 09:52 AM
slow coach's Avatar
Default Losi 8 1.0 to 2.0
Hi need an answer on the original losi 8, I am helping a mate out with a gearbox rebuild on his losi 8, its the original version with a few 2.0 parts on it, he needs to replace the rear housing because the diff inserts are moving around badly in it, if i put it back like that im fairly certain it will strip the gears again, anyway the question is will the 2.0 housing bolt straight on to the older chassis or will it cause other issues??
slow coach is offline
Old 05-13-2013, 09:12 AM
Yes it bolts on - you need to use the bearing inserts it came with.
token is offline
Old 05-18-2013, 03:53 AM
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
http://www.rctech.net/forum/r-c-item...parts-new.html
XXXDad is offline
