need help completeing my idea >
Old 05-01-2013, 03:18 PM
fordman86's Avatar
Trader Rating: 35 (100%+)
Default need help completeing my idea
I decided to make a hommade tire storage device. But I am stuck I am wanting to put a grab handle the folds down kind of like a drawer. wanting to put a washer where the nut would normamly sit but am lost after that anyone have an idea for a handle the rod is 5/16.
fordman86 is offline
Old 05-01-2013, 03:48 PM
sschultz's Avatar
Trader Rating: 15 (100%+)
Am not sure what you mean by the fold down drawer thing. Take a 5/16 nut to your local welding shop and have them weld a loop or handle of your liking on it....
sschultz is offline
Old 05-01-2013, 03:58 PM
fordman86's Avatar
you know how some drawer handles lay flat until you grab them
Old 05-01-2013, 05:35 PM
hustler777's Avatar
What you could do is mount a folding drawer handle to a peice of flat steel or aluminum then have it tapped for 5/16 so it replaces the nut.
hustler777 is offline
Old 05-01-2013, 08:12 PM
fordman86's Avatar
Was thinking of this and this some how.
Old 05-01-2013, 08:26 PM
sschultz's Avatar
Cut a slot on 2 sides of nut in pic. Install d-ring, and install plug on top to lock d-ring in place...
sschultz is offline
Old 05-01-2013, 08:46 PM
fordman86's Avatar
That's what I thought drill a couple holes and get an unwelded d ring they plug it
Old 05-02-2013, 07:36 AM
mxr17's Avatar
Why don't you just drill a hole to that threaded piece and just install a simple key ring, that would make it simple and no need of welding, just need a drill and some key rings and you would be good to go.
mxr17 is offline
Old 05-02-2013, 07:39 AM
Turn the whole stack upside down and grab it by the hub?
Matthew Bailey is offline
Old 05-02-2013, 09:33 AM
Drill a hole in the threaded rod and attach a key ring. Then use the key ring and loop a rope through it. Handle DONE!
Klimpen717 is offline
Old 05-02-2013, 04:45 PM
fordman86's Avatar
Not only do I want a handle want to to look good as well.
