Nitro rc car quitting >
Old 04-12-2013, 03:08 AM
Default Nitro rc car quitting
When I go to start the car, I put the car on a platform where the wheels are not touching the ground. I start the car and every thing is going well. So I put the car on the ground to drive it. Once the cars wheels touch the ground the car quits.
Please help!!!!
dazablue is offline
Old 04-12-2013, 03:12 AM
morgoth's Avatar
Sounds like a bad clutch bearing or broken clutch spring.
Have you tried rolling the car over the ground? You should hear that something is dragging or even feel it.
morgoth is offline
Old 04-12-2013, 03:18 AM
Ye I do feel something when I roll it on the ground
dazablue is offline
Old 04-12-2013, 03:52 AM
Suspended
Yes i'm agree with Mr. morgoth there is something wrong with cluth bearing.
charlesnitrotek is offline
Old 04-12-2013, 04:05 AM
morgoth's Avatar
Then I'd check the clutch shoes/springs and the clutch bearings.
If a clutch spring is broken, the will stop when touching the same.
The same counts for a bad clutch bearing.
morgoth is offline
Old 04-12-2013, 04:24 AM
nathanjohnzrc's Avatar
am sure this problem due to the clutch bearing. You must replace the clutch bearing. If you know how to replace it then you do yourself other than you must have to go RC store.
nathanjohnzrc is offline
Old 04-12-2013, 05:08 AM
morgoth's Avatar
Double post
morgoth is offline
Old 04-13-2013, 05:34 AM
I checked the clutch and the clutch spring was broken so i replaced it so now every thing is working
dazablue is offline
Old 04-14-2013, 11:28 PM
Thumbs up
Really great (dazablue) you have solved your problem. You have done it yourself or with the help of any store? Now you can enjoy with your Nitro RC car. It's really made great fun.
