NEED DRIVE SHAFT PINS CHANGED !!! >
Old 04-04-2013, 08:58 AM
Default NEED DRIVE SHAFT PINS CHANGED !!!
Hi: All
I got an Xray 808 second hand a few days ago and I need to get drive pins replaced is there anyone on there that could offer such a service. Or someone that has the tool to do this and maybe figure something out!!!
Your comments are as allways very well appreciated
Tracker Ryan is offline
Old 04-04-2013, 09:26 AM
Jaz240's Avatar
Trader Rating: 52 (100%+)
You can send them to me or find a local racer with the pin press tool. I'm positive someone at your local track will have one.
Jaz240 is offline
Old 04-04-2013, 03:24 PM
EJF
EJF's Avatar
Trader Rating: 41 (100%+)
mugen and hudy both make tools to do this, i use a cheap chain breaker tool, it works but is a pain at times.
EJF is offline
Cool Beans
I live in Waterford Ireland and I do not have a track near by and no model shop neither some joke eh!!!
How will we do this
So I will have 6 pins to replace cause there all very bad
Old 04-04-2013, 03:34 PM
Hey: EJF
Was thinkin of a chain breaker meself not sure if l have one lyen around though,
Yeah I know about the hudy tool but its like a hundred bucks!!
Old 04-04-2013, 03:38 PM
nitroexpress's Avatar
FWIW
RCRenew has a $50 tool.
http://www.rcrenew.com/tools.html
nitroexpress is offline
Old 04-04-2013, 04:03 PM
packerbacker's Avatar
Mugen or Hudy tool is your best bet if you plan on racing for any amount of time. We keep ours replaced on a regular basis and is well worth it. One of my have to have tools.
packerbacker is offline
Old 04-04-2013, 04:15 PM
TX_Punisher's Avatar
Hudy is so simple to use. Tried another one listed in this thread and broke it the first time I used it.
TX_Punisher is offline
Old 04-04-2013, 05:01 PM
ecpete's Avatar
Trader Rating: 39 (100%+)
Originally Posted by nitroexpress View Post
FWIW
+1. I use this tool and it makes changing out Drive Pins really easy. I've used it so far on my Agama, my old Losi 2.0 and Mugen MBX6.
ecpete is offline
Old 04-04-2013, 06:44 PM
Trader Rating: 29 (100%+)
Just got the Mugen tool, and it works really good.
Highly recommend.
madhammer is offline
Old 04-04-2013, 07:11 PM
FWIW
+ 1 for the Rc renew tool. Used the hudy one before and the rcrenew one is easier to use and better value for money
Flip it is offline
Old 04-04-2013, 11:11 PM
Jaz240's Avatar
Originally Posted by Tracker Ryan View Post
Cool Beans
How will we do this
Wow you are in Ireland? I think back and forth shipping to me will be more than buying new CVD's. would you like me to ship you a pin press tool? I stock the Hudy, Mugen and can get the RC renew one as well.
Jaz240 is offline
Old 04-05-2013, 12:22 AM
sschultz's Avatar
Trader Rating: 15 (100%+)
If your creative, a bicycle chain breaker does the job!!! sorry to the manufacturing guy's.
sschultz is offline
Old 04-05-2013, 12:44 AM
You don't really need those pin tools. I just changed 6 pins from my swing shafts without those tools. I used my vise to press the pin out of the shaft and into a 5mm socket (1/4" drive). That gets one end of the pin flush against the ball thing its pressed in and the other end of the pin pushed outward into the socket. Next, I used a 2.5mm diameter pin (Mugen E0238) held with pliers to put against the pin that is flush with the ball thing and squeezed the vise closed. Since the 2.5 mm diameter pin is smaller than the ID of the ball thing, it pushes the pin you're replacing all the way out and into the socket and then the 2.5 mm pin falls out easily. Using pliers position your new pin (make sure its the correct diameter... Kyosho is a weird size) at the opening of the ball thing of the swing shaft you want to push it into. Put the socket at the opposite side of the ball thing. Close the vise. The pin will push through and into the socket. Eye ball it. Then measure. Adjust as needed. After you do two pin replacments, it only takes a minute. It's easy and cheaper than the tool.
My ST-RR EVO is offline
Old 04-05-2013, 03:01 AM
1BLADE1's Avatar
yep, have to admit the vice thing works really well .....
if in a pinch and no tooling it is the easiest way to go
we also make some tooling for this as well...
the mugen one is nice as well...we tried this one too....
ours is a little like the Hudy one but without the Price tag!
$48.00 for ours,
and because the Punch part of tool can not go all the way down
you can't pinch your finger or hand....
other ones are good !! but ones where they do not use a twisting motion
seem to have better results, the Hudy is the most effective one but there
$100.00
the vice or a type of press is the best option.
we use the same when in our shop we use a press,
if you are in the Field(track, local park etc.) a portable one is a nice solution.
if you have any Question please do let us know at
[email protected]
here are some pics...
the other punch has a smaller Diameter pin to push
the pin the rest of the way out
1BLADE1 is offline
