odonnel fuel
Old 03-31-2013, 05:08 PM
Default odonnel fuel
hey guys our local lhs is switching to odonnell fuel and i would like your input on which i should run. rtr fuel, racing blend or speed blend? i have an lrp .28 running 30% & currently running s&w fuel. i do race but not overly serious. also what glow plug would you suggest? thanks for help.
rubberneck is offline
Old 03-31-2013, 05:55 PM
GNS Racing 86's Avatar
ive been running the speed 30% all last yr, racing only, no problems, ODonnell 97t turbo plug has been awesome. make sure you have a turbo head button if you use that one, i believe its a medium temp plug
i run a series race and one of the sponsors was ODonnell and won 6 qts on the door prizes, been using it ever since. i was using byrons raceblend did not notice any difference
GNS Racing 86 is offline
Old 03-31-2013, 05:56 PM
Stubbs's Avatar
Trader Rating: 58 (100%+)
The Speed blend is the newer formulation. It's 7.5% oil (castor / synthetic) mix, with relatively low viscosity. It's a really good fuel, but it's meant more for the hardcore racer, who's looking to get top performance out of the engine, at the expense of some longevity.
The race blend is the original formulation, and is also great fuel. It's what I ran before Speed Blend came out. It has more oil percentage, and will protect the engine better.
If you're a casual racer, and are more concerned about engine protection versus peak performance, I'd go with the RTR, or Race blend.
Stubbs is offline
Old 03-31-2013, 06:21 PM
thanks for input guys. i think i should probably go with race blend. also the lrp .28 is stock ( no button head ) & calls for 25% but i run 30%. is that ok for engine?
Old 03-31-2013, 06:24 PM
does anyone know if hudy has bearing puller tool for .28 bearings?
Old 03-31-2013, 06:36 PM
jmaxey51's Avatar
Actually the speed blend fuel changed about 6 months ago, it's now 8% oil. I've been running it sense it came out, couldn't be happier with odonnell fuel.
As for the bearing puller, the one that they have works for .21-.28 , it may even work up to a .32
jmaxey51 is offline
Old 03-31-2013, 06:41 PM
thanks for help guys very appreciated
