TLR 8 3.0 BUILD WITH PICTURES
#46
The new 15 deg plastic non inclined caster blocks and spindles are redisigned to maximize steering throw with more clearance for the wheel
First and foremost, Thanks for the highly detailed post for the build, It was very thorough and clear.
But, I had a question about the caster blocks. So no more inclined blocks for the 3.0? I felt they toned down the steering entry whilst giving more exit speed. I'm pretty sure the 2.0's stock blocks had a total of 20 degrees of castor and the new 3.0 now has 15 degrees? Does the chassis have more kick up than stock?
Thanks, Jim
Thanks, Jim
#47
The old blocks were either 10 degree or 12 degree depending on the particular model of car. These are 15 which will give it an additional 3 or 5 degrees over the old cars
At least I think that is correct.
#48
Thanks, Jim
Thanks, Jim
And yes Matt you are correct
#49
So I assume you have had a chance to run the car a few times. I am curious how the new hubs affected the handling. I have always felt that 12 degree hubs left the car feeling twitchy. I drove the JQ which has 15 or 16 degree hubs and it turned smoother. Did the new hubs have this same type of effect?
#50
Does the 3.0 come with metric or imperial screws/nuts
#51
Imperial
#52
Yep
#53
wonder if the 3528 with the metal inserts would be better used for the front diff because i can see it giving less diffing action compared to the 3500 diff cups for the rear. i would imagine that the metal inserts would give the gears a bit more controlled friction...hence, less diffing action and more pull out of the turns..........what do you think...??
#54
#55
#56
Only problem I can see is that it won't be consistent. The more you run the diffs, the smoother they get. It would be hard to keep them consistent with this method. Just using oil means all you have to do is replace the oil to return it to the diff action you want. Unless you really just want to run the old cases to get rid of some extra parts, there is probably no real good reason to do this. Plus I am pretty sure the old cases with steel inserts weigh more so you are increasing rotating mass.
#57
Get DE Diff inserts then the diff weight is negligible. Ive been running mine for quite some time now and haven't noticed a lick of play.
#58
I know this is the nitro section....But I can't wait to convert one to E!!
