Team Associated RC8B3 Nitro Team Kit >
Like Tree127Likes
    Hide Wikipost
Old 09-05-2016, 09:19 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC8B3 Nitro Team Kit
Last edit by: 190mph
Welcome to the RC8B3 Wiki!
Feel free to share Tips, Tricks, and anything else beneficial to the RC8B3 nation!
Instruction Manual and Setup Sheets:
RC8B3 Instruction Manual
Blank Editable Setup Sheet
Base Setup Start Here (Dirt Nitro Challenge 2016 Team Setup)
Browse Posted Team Associated Posted Setups
Browse Posted Petit RC Posted Setups
Print Wikipost
Old 08-14-2021, 03:19 PM
  #4246
asirolli's Avatar
Originally Posted by Divey View Post
That a bummer. So hard to find parts. I have found some but at a premium price
Thanks for the feedback guys.
I was able to fit a RC8B3 diff and pinion in a RC8…. you will need a new set of 4 bearings with smaller inner diameter for the gearbox/pinion and shim it properly to match the pinion to the diff gear (~1-2mm shim between the pinion and gearbox.
asirolli is offline
Old 08-14-2021, 03:25 PM
  #4247
Divey's Avatar
Trader Rating: 117 (100%+)
I just picked up a RC8T3.2e. Gonna see first hand what I could and can work. I like my original rc8t and rc8b I just don't want to get rid of them. Now if I could find a tekno v4 kit for the truggy I would be golden. Had one back in the day and loved it.
Divey is offline
Old 08-15-2021, 08:58 AM
  #4248
Is there a specific rc8t3.2 thread? Can't find it. I'm looking for options about chassis sticker
lephil is offline
Old 08-15-2021, 09:04 AM
  #4249
Divey's Avatar
m2C racing. That's what I'm gonna do..
Divey is offline
Old 08-15-2021, 12:26 PM
  #4250
didn't see anything there...
lephil is offline
Old 09-04-2021, 11:02 AM
  #4251
Divey's Avatar
woops, just realized what you wrote. To answer your question, no there is not an rc8t3.2e thread. Only the original rc8t3 which I have read thru.. all those issues have been fixed. Also did you mean thicker chassis. M2C racing makes a 7075 chassis for the rc8t3.2e which is supposed to be stronger than stock. I believe it's still in stock on amain.
Divey is offline
Old 08-13-2022, 07:03 PM
  #4252
What rod ends are we using now as 81400 is discontinued? I'm talking associated only.
willsy8.2 is offline
Old 08-15-2022, 12:46 PM
  #4253
Stealthpilot's Avatar
81521 are the B4 rod ends, they are a direct replacement.
Stealthpilot is offline
Old 10-07-2022, 01:30 PM
  #4254
Woof6's Avatar
Trader Rating: 35 (100%+)
Hi All,
Looking to get into nitro buggy, probably with a 3.1/3.2. (if anyone has a roller cheap pm me ). My question is this. Most used rollers don't come with flywheel/clutch/endbell assembles. Will any mfg setups work? I realize tooth count may vary, but are there any other differences? Thanks for the help
Woof6 is offline
Old 10-09-2022, 04:05 PM
  #4255
predu's Avatar
Default Setup help
Does anyone have a good set up for a rough track? I've tried lots of things and my biggest problem is the rear seems extremely loose the car does not feel balanced I've tried a bunch of setups online and they just don't seem to work
predu is offline
Old 10-27-2022, 11:29 PM
  #4256
whats your current setup now?
But a shot in the dark...i would try and shave 1mm off the front of the rear arms, and add 1mm shim to the back of the arm. Shock package: front (3x1.4, 2x1.5) 40wt, rear (3x1.5, 2x1.6) 37.5wt. Stiff bladder at full rebound. Maybe add a bit more rear toe to help track straight
rendizzle is offline
