Team Associated RC8B3 Nitro Team Kit
#4186
That has a massive difference in how the rear end behaves, as the roll center stays lower throughout the turn, compared to the 3.1 short arm setup.
The end result is that the rear end reacts a lot smoother.
To bring up the level or response in the rear end, I run stiffer rear springs and sometimes higher roll center.
Also, I find a slightly longer front upper arm helps to balance out the feel of the longer rear arm.
The other very noticeable change is the new shock bladders. Compared to emulsion, it makes the car more responsive, which I like. You can still run emulsion if that's your preference.
#4187
Is there any time that you switch back to the short arms?
#4188
No, I haven't. In general the car is more stable and predictable with the longer rear arms.
And it's such a big change that you have to dial the rest of your setup to it. Going back would take a bit of unwinding, and I can't see where it would be a benefit... maybe on a very small track with tight switchbacks?
#4189
#4190
I had seen a lot of Losi owners putting the Tekno hinge pin bushings in their arms, and I decided to try it in my RC8B3.2. Well worth it in my opinion. It really frees up the arms and keeps them that way. No more dust making everything tighten up after a couple of runs. So far I haven't seen any durability issues at all, although I only did the lower arms. I will try doing the upper front arms at some point. If you want to try it, use a #9 drill bit (0.196) and drill all the way through. I used a drill press at a low speed. You aren't removing much material at all so if the arm tries to "walk" up the bit, just let it. The bushing will be press fit, but not tight. The part number for the bushings is TKR9055.
#4191
Any new update coming for the ae 1/8th platform?
It seems everything is quiet and seeing some race pics no new part is being tested....
#4192
#4194
They actually measure out to just under that: 12.75mm and fit perfectly into the outdrives, that measure at 12.63 +/- 0.02 at the slot, depending on where you measure them.
I know that some guys opted for slightly shorter pins in the middle, like the H0853 3x11.8, to make sure that they don't interfere with the brake disk. I didn't find any issues with using the same 12.8 pins... even if they measure out a hair wider, if you run your finger across they don't protrude out. Also, the brake disk opening is 13.20mm and there's enough slop in the system... it's never been a problem for me.
I found the shorter ones way too short, when I tried them... they don't engage on the entire outdrive and wear a groove in faster.
#4196
Pillow balls
I didn’t find this on this thread, so let’s begin
Why some cars @ the Words were using aluminum pillow balls in the upper and steel in the lower?
#4197
