Team Associated RC8B3 Nitro Team Kit >
Like Tree57Likes
    Hide Wikipost
Old 09-05-2016, 09:19 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC8B3 Nitro Team Kit
Last edit by: 190mph
Welcome to the RC8B3 Wiki!
Feel free to share Tips, Tricks, and anything else beneficial to the RC8B3 nation!
Instruction Manual and Setup Sheets:
RC8B3 Instruction Manual
Blank Editable Setup Sheet
Base Setup Start Here (Dirt Nitro Challenge 2016 Team Setup)
Browse Posted Team Associated Posted Setups
Browse Posted Petit RC Posted Setups
Print Wikipost
Old 04-12-2019, 04:05 AM
  #3916
ZEe_NYC's Avatar
Trader Rating: 34 (100%+)
Default wtb parts
does anyone have a small parts lot theyíre willing to sell? I have a 3.0 and am looking for race replacements, before I order from amain (arms, hinge pins, shock shafts, etc... prettt much anything that will leave me stranded on race day)
thanks guys
ZEe_NYC is offline
Old 04-12-2019, 11:21 AM
  #3917
Originally Posted by ZEe_NYC View Post
does anyone have a small parts lot they’re willing to sell? I have a 3.0 and am looking for race replacements, before I order from amain (arms, hinge pins, shock shafts, etc... prettt much anything that will leave me stranded on race day)
thanks guys
Ebay will get you a better bang for the buck. Lots of guys strip down kits and sell parts lots. You will need to do a little research as prices are all over the map and if you get a bunch of crap form different sellers, the shipping will reduce the savings. nitromaster on Ebay is usually pretty good on prices and combines shipping. Sometimes the price of buying things like a whole set of shocks makes sense, when you figure you are getting, shafts, spring cups, shock ends, seals etc. so keep that in mind.
Remember the 3.0 arms are a little different, as are the ABC and D blocks, and driveshafts.
ZEe_NYC likes this.
largeorangefont is offline
Old 04-12-2019, 11:24 AM
  #3918
Any feedback on the new adjustable 4 shoe clutch yet? I'm not sure if I need this $50 flywheel in my life.
Old 04-12-2019, 02:48 PM
  #3919
How do you fix the broken screws in clutch assembly? The head on the screw holding clutch shoe and spring broke of canít figure how to get rest of pin out to reuse clutch system .
Ofna2005 is offline
Old 04-15-2019, 10:30 AM
  #3920
sunco1's Avatar
Trader Rating: 29 (100%+)
Cut the screw out. You will probably lose a spring but might be able to save the shoe.
Tips for assembling the clutch pins.. no thread lock and don't over-tighten them. Just hand snug is fine. The rotation of the crank will naturally want to tighten them. I find that most of the time when they break, its because they were too tight.
sunco1 is offline
Old 04-15-2019, 02:55 PM
  #3921
MaricopaAgent's Avatar
Trader Rating: 28 (100%+)
Have broken many.. Probably in the 5 to 7 range. Unfortunately, I just trash it. Hard to justify the time to get the screw out. But, I do install new screws often now.
MaricopaAgent is offline
Old 04-20-2019, 08:40 PM
  #3922
So, after snapping yet another screw, I thought about this thread today.
Since almost all of the threaded part comes out when it breaks, I bent the shoe as far back as possible, which in turn , loosened the last bit of thread enough to remove it with pliers. Came out really easy.
Old 04-21-2019, 10:20 AM
  #3923
I have not broken one yet. I use a very light amount of anti sieze on the clutch pin threads.
Old 04-21-2019, 02:44 PM
  #3924
The threads have nothing to do with it breaking. The Pin fully floats and holds the spring. This is why most of the threads come out.
Run yours much longer, it'll break.
Old 04-21-2019, 11:00 PM
  #3925
Default Shock bushing measurement
Could some one throw calipers on the 'shock bushing' (where the upper shock mounts too) and tell me the diameter of it is. Mine has a ton of slop and I dont know if it's the cap or mount.
Thanks in advance.
jlett21 is offline
Old 04-22-2019, 11:46 AM
  #3926
So the pin is bending you are saying? I have been proactively changing the pins when they start getting hammered.. they are certainly a wear item.
Old 04-24-2019, 11:55 AM
  #3927
skrichter's Avatar
Does anyone make a lightweight (steel) spur gear yet? Thx!
skrichter is offline
Old 04-24-2019, 03:51 PM
  #3928
sunco1's Avatar
Why do you want that?
sunco1 is offline
Old 04-24-2019, 05:29 PM
  #3929
kdub's Avatar
I unthread the screw head when it breaks. Then to get the shaft out, use the blade on your xacto, dig into the pin near the spring coil, and you can walk the shaft out a little at a time. Never had to trash a spring or shoe and I've done this 3 times. I was just emailing the AE guys to switch to 1.5mm hex on the screw head so the thin wall from 2mm hex won't break so easily.
kdub is offline
Old 04-24-2019, 05:36 PM
  #3930
kdub's Avatar
Default Thornhill Nitro Setup- Kurt "Coach" Wenger
RC8B3.1 for Thornhill in Texas (covered, low dust, huge, fast)
kdub is offline
