Team Associated RC8B3 Nitro Team Kit >
Like Tree47Likes
    Hide Wikipost
Old 09-05-2016, 09:19 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC8B3 Nitro Team Kit
Last edit by: 190mph
Welcome to the RC8B3 Wiki!
Feel free to share Tips, Tricks, and anything else beneficial to the RC8B3 nation!
Instruction Manual and Setup Sheets:
RC8B3 Instruction Manual
Blank Editable Setup Sheet
Base Setup Start Here (Dirt Nitro Challenge 2016 Team Setup)
Browse Posted Team Associated Posted Setups
Browse Posted Petit RC Posted Setups
Print Wikipost
Old 02-01-2019, 09:04 AM
  #3871
Originally Posted by sunco1 View Post
I really liked running the 42/12 gears at Rev. That surface can get pretty rough and the under drive gears help keep me from getting out of control as quickly.. especially when i'm running a fire breather OS motor
I'd also like to point out that the AE angle tapered pistons are not identical to the Kyosho pistons. There are some subtle differences that I think make them a lot better suited for our car.
Have you tried the short link, narrow pivot setup at Rev yet? If not, you should give it a try. Compared to the longer link normal setup, the car rounds through corners a lot smoother and with less twitchy input to the steering wheel.
Nice, that is encouraging about the pistons and the gearing, I am excited to try it. Thanks for the setup, I will give it a shot. That is the direction I was going to go with the links. The car is about 85% there now, but smoother cornering is what I was looking for.
I have the shocks stood up all the way out at the tops and bottoms front and rear and that really helped as the track is getting rougher every passing week, that took some of the twitchiness out. I think the shock setup on your sheet will be a bit too stiff for Rev at this moment, but I will try all the geometry changes and see where it lands.
largeorangefont is offline
Old 02-01-2019, 05:00 PM
  #3872
TOO-TALL's Avatar
Are you running the underdrive gears 42/12 in the rear only??
TOO-TALL is offline
Old 02-02-2019, 06:53 PM
  #3873
Yea just the rear. If you ran them front and rear you’d get no underdrive.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
