Team Losi Racing 8ight 3.0
#1411
Are u guys finding that there's a lot of play between the shock cap and standoff bushing? It seems to me, its the shock cap thats developing the slop and not so much the bushing. Is there a fix, other than replacing the shock caps. My rears are really bad, so I'm going to try fuel tubing as a bushing.
Anyone tried vented shock caps yet? It would be nice to get second opinions. I have been running them about 8 gallons now with zero problems. So if you're bored try it.
#1413
A few months ago I was working on getting rid of slop in the eyelet of the shock cap on my Intech buggies. I made some bushings from a couple different materials. UHMW was the best until I found a common tubing we keep in stock at work. I just cut the shoulder off he existing bushing and installed about .1875" of this tubing and it is bulletproof. It doesn't wear and takes out all the slop. Plus, it's soft enough to provide impact resistance (or however you look at it).
I will check to see if it works on the 3.0.
#1414
Keep us updated.
#1415
#1416
Hey Ben, post a pic if you could please.
#1418
Let me see if I get this right, you take the original plastic standoff piece that the shock mounts to and cut it in half using the smaller side to slide on then use about the same length you cut but of fuel tubing and basically go half and half plastic/fuel tubing because the fuel tubing is a little thicker thus eliminating slop but not affecting or binding the movement because its only half the amount of tube in the eyelet instead of being a full piece that could bind it really bad. Am I right? Sounds good, u may have a tiny amount of bind but none noticeable.
#1419
Fuel tubing doesn't do what I have had the experience of with this tubing. It's nothing special. It does take a race to break it in but then works very well. I have some sitting in front of me. I just have to find out if it fits the Losi and what material it is made out of. We have a few different kinds.
#1420
http://www.coleparmer.com/Product/Be...ck/EW-06491-12
That is what I used. I did try to fit it on my buggy. It's too tight. I don't know if it would be worth drilling the shock cap. I don't like the idea of reducing material at the eye of the cap.
#1421
After doing some measuring. This "may" be the ticket in case any of you want to try it.
http://www.mcmaster.com/#5958k13/=o41377
#1422
Hey guys, Today I ran my 8ight 3.0 for the first time at the track today. ust finishing breaking in the motor and some light practice.
What should I check after its first real run?
I have already checked the rear diff for wear and everything seems fine even the bearings are like new still after about an hour of running. I have also checked for loose screws and all seems to be ok. Am I missing something?
I did have one issue. The rear shocks collars moved during running a lot changing my rear ride height at least 5-7mm lower from where I started (29mm). The lower ride height also made my rear springs pop out of the cups. This is how I noticed something was wrong. At that time I only was on the track for maybe 20 minutes max.
Did my shock collars spin loosening the springs? What should I do to stop this?
thanks for any help here.
#1423
The springs break-in too. Not the collars moving.
#1424
The springs do bed in slightly , you will prob find its due to getting a small amount of dirt / binding in the rear hubs and hinge pins
#1425
Well, that explains everything. Thanks I did notice the front also lost its ride height setting but not so much that the springs popped out of the cups.
Small amount? Dirt gets everywhere but it didn't seem to bind anything. I had nice smooth motion all day. I did take apart the rear suspension to inspect the hinge pins and they also seem like new still.
So for what was basically an hour long bashing session. Since I haven't driven a nitro car for around 10 years. The 8ight 3.0 handled it a lot better than my old MBX 4 would have and I considered that thing a tank.
