What tool do you use to tighten the bottom engine mount screws? >
Old 12-09-2012, 06:29 PM
  #16
coneman's Avatar
Originally Posted by chopper82p View Post
Hmmmm....
Blue loctite and a hex driver? No need for power tools or torque wrenches.
+1000. all u need
coneman is offline
Old 12-09-2012, 06:34 PM
  #17
kja812's Avatar
I use Loctite 222MS and hand tighten the engine mount to the chassis. I also keep a separate Hudy 2.5 bit just for installing and breaking loose engine mount screws so the tool is always in like-new condition.
kja812 is offline
Old 12-09-2012, 07:18 PM
  #18
hustler777's Avatar
Hmmmm....
Do you actually think there's guys out there that use a torque wrench?? Really!? LMAO!!!
I do use a 1/4" power driver tho..... just cuz i can...lol
hustler777 is offline
Old 12-09-2012, 08:08 PM
  #19
ecpete's Avatar
Trader Rating: 39 (100%+)
I use the Craftsman 2.5 mm T Handle Wrench and Blue Loctite.
ecpete is offline
Old 12-09-2012, 08:26 PM
  #20
Frank L's Avatar
Trader Rating: 148 (100%+)
Hudy, exceed or arrowmax tools. I have always used hudy but recently tried the other 2 companies and their told seem to be holding up to the task.
Frank L is offline
Old 12-10-2012, 06:43 AM
  #21
teeforb's Avatar
Trader Rating: 94 (100%+)
That's what I need, a T wrench. Does any of these tools make a T wrench?
teeforb is offline
Old 12-10-2012, 07:07 AM
  #22
RCmayor's Avatar
http://buy1.snapon.com/catalog/item....re&dir=catalog
One of these with a good 1/4 hex driver bit.
RCmayor is offline
Old 12-10-2012, 11:10 AM
  #23
madweazl's Avatar
Losi hex driver and I dont use loc-tite. I do check the vital screws before each run and the vehicle is torn down after each event though. I've never had an engine back off before.
madweazl is offline
Old 12-10-2012, 01:50 PM
  #24
blis's Avatar
Originally Posted by teeforb View Post
The ones at the bottom of the chassis where you adjust the gear mesh. I've had problems where the motor has moved.
I would suggest a good clean of both surfaces and ensure there are no burrs or kinks before any tool becomes a factor. Also if the screws protrude they could be getting knocked as you bottom out. Then as we do in on road, once you've have your mesh set and engine mount tight, remove the engine from above using a 2.5 ball if possible. Over tightening could be deforming the alu and once that's happened, it's a new chassis plate.
Loctite wont stop the mount slipping if there's grit under it, it'll just prevent the screws from falling out.
h
blis is offline
Old 12-11-2012, 06:30 AM
  #25
Hoese37's Avatar
Hmmmm....
Make sure the threads are clean on the screws and mount before adding loctite. I usually use a wire wheel in a dremel and some motor speay on the screws, and motor spray and trhead in a long screw in the mount.
Hoese37 is offline
Old 12-12-2012, 10:23 AM
  #26
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
This works great
Rich Panganiban is offline
Old 12-12-2012, 11:22 AM
  #27
Roelof's Avatar
As mentioned, torx is the way!
I also have a T-wrench and the screwas wit an integreted washer, easy to get at a good hardware store.
Attached Thumbnails What tool do you use to tighten the bottom engine mount screws?-torx.jpg
Roelof is offline
