Mugen MBX7
#8611
I am a pretty aggressive driver and in over 2 years I have broke 1 front upper arm and 2 front lower arms, that's it. They are very durable cars that don't wear out near as fast as some others. You can boil the front lower arms and it helps against breaking but any part will break if you hit something hard enough.
#8613
Chassis length is the same.
#8616
Hello,
I was running today at the club's track and I have some difficulties setting up the mbx7 for it.
The track is normally relatively smooth but they're some potholes there and there due to wear. The surface is hard packed with quite a lot of dust over it ( white clay type earth).
I tried the std set up and tried to improve the lack of grip.
At the moment the set up is :
-high roll center front
-I tried the highest roll center at the rear (hub carrier HRC+ shock tower lowest position) but the car would still slide easily and it was very hard to control it back.
-Camber link at the moment is middle (I tried both longest and shortest without curing the problem)
-neutral kick up
-neutral caster
-1° camber at the front 2° at the back
-600sct oil at the front with 8x1.2mm piston 450cst rear with the same piston
-5000sct front, 8000sct center and 3000sct rear diff.
I had city block at the front and I beam at the back all new.
-22mm ride height and the front 27mm back.
-neutral antisquat.
-2.5mm anti roll bar front and 2.7mm at the back.
-8.25x1.6 front spring
-10.75x1.6 rear spring
I liked the responsiveness of the high roll center but I was losing a lot of my time when the rear slide and had to slow down to get control back.
At the moment I'm thinking of going to 450-500cst front and 325-350cst at the back perhaps.
Many thanks in advance if you can help me
Jonathan
-neutral kick up
-neutral caster
-neutral antisquat.
Jonathan
#8617
So i bought a used MBX7 from my buddy. And im curious to know how to takw diffs apart. Are there any videos out there? Thanks in advance
#8618
I know it's a buggy thread but asked Mugen about MBX7TE (which is out of stock everywhere) and recieved this email:
Dear Peter,
thanks for contacting us.
The Truggy MBX-7 is already in production and will be available all over Europe very soon.
Of course, this will be an Updated one like Buggy "R" and get some improved performance as well, like Buggy "R".
Stay tuned, the kit will be at the shops we guess end of October.
Best Regards / Cordialement
MSE Mugen Seiki Support Team
Dear Peter,
#8619
is the rumored MBX8 to be introduce in Vegas?
#8620
