Like Tree1Likes
Mugen MBX7
Old 06-23-2013, 03:42 PM
  #4921
gixxerman's Avatar
Originally Posted by munrath View Post
Kevin - Take the a-arms off the car and boil them for 15 minutes, let cool and then install them.
Mark
+100! I started doing that a while ago and never had a problem again.
gixxerman is offline
Old 06-23-2013, 04:10 PM
  #4922
beidle99's Avatar
I have never had to boil parts so please help me out here.
do you bring the water to boil and then put the parts in for 15 minutes? Or do you put parts and water in pot and then once boiling start timer for 15 minutes?
beidle99 is offline
Old 06-23-2013, 04:31 PM
  #4923
ronsand's Avatar
Do not over think it Put the plastic in slightly boiling water (simmering), and leave it there for some time (I usually do 30-45 min). Let the plastic cool down in the water.
Presto... dinner served
ronsand is offline
Old 06-23-2013, 06:18 PM
  #4924
Kevin_M's Avatar
Mark
Mark I did boil them. Even though i did boil them the part was going to break due to impact on a pipe lol. I ordered 3 sets of arms now I hope they will be here before next weekend.
Kevin_M is offline
Old 06-23-2013, 06:20 PM
  #4925
A very good post about boiling plastic:
http://www.rctech.net/forum/8466992-post24.html
Bappen is offline
Old 06-24-2013, 12:58 AM
  #4926
Hello,
i often red about setup to use 7-7-3 and i tried it but i have a lot of front tire wear.
In a final of 30 minutes the front tires have no profile after 20 minutes. Thetas not normal for me. It is the same on tracks with grip or with less grip. On less grip tracks a can drive 25 or 30 minutes but this tire wear is horrible for me.
Has anyone a solution for it ??
ddick is offline
Old 06-24-2013, 02:18 AM
  #4927
Trader Rating: 95 (100%+)
Default Plastic
A fellow racer that works with plastics told me that to condition the parts just put them in a ziplock bag with distilled water. No need to boil them.
latemodel13 is offline
Old 06-24-2013, 03:33 AM
  #4928
Default RB damping system setup
Ok, so the problem is that I have that new system in box waiting to put it on. But I like to first get some feedback from somebody who has been using/testing it with MBX7. What kind of springs/oil combos you have been trying and what to try next, In RB own pages they told to use 1000/850 oils but there was no mention about springs.
RookieForever is offline
Old 06-24-2013, 03:36 AM
  #4929
morgoth's Avatar
Originally Posted by ddick View Post
Hello,
1. Be more gentle with the throttle
2. Softer clutch setup (does the same as 1)
3. Ticker center diff oil, but the rear will break out faster on throttle...
morgoth is offline
Old 06-24-2013, 04:49 AM
  #4930
Use same springs as with standard dampers.
ddick is offline
Old 06-24-2013, 04:53 AM
  #4931
So now i have a problem :
1) i am gentle with the throttle cause of the loose rear
2) softer than 1.0 springs in the clutch ?
3) this the problem with the looser rear.
I donīt understand: i have a car and should drive fast but cause of tire wear i should drive slower You are right but this is horrible or the MBX-7 is not a good car in my eyes.
Thanks for the solutions but donīt help me cause i tried point 1 and 3 (
ddick is offline
Old 06-24-2013, 05:19 AM
  #4932
Maxxed-out's Avatar
Trader Rating: 15 (100%+)
Try 10-7-5, put the rear hubs in the upper holes and put the rear hubs all the way forward.
Maxxed-out is offline
Old 06-24-2013, 05:45 AM
  #4933
TheBackmarker's Avatar
Hello,
If you are roasting front tires prematurely, one of two things is happening. Either:
1. You are diffing out excessively to the front wheels under acceleration and spinning the tires like doing burnouts in a full-size front wheel drive car. Morgoth's advice addresses this perfectly.
2. You may have excessive toe in or out, which is like dragging the tire sideways down the track. Set 0 toe to SLIGHTLY toed out like 1 degree and you will maximize tire wear.
TheBackmarker is offline
Old 06-24-2013, 07:02 AM
  #4934
Numburn's Avatar
The front tires normally wear faster on any buggy. If the difference is excessive, try what the others posted as they are good ideas. Going up in the front diff like Billy suggested should be your first step. It will not only reduce tire wear but will take some twitchiness out of the car.
Numburn is offline
Old 06-24-2013, 08:21 AM
  #4935
tom1974's Avatar
i advise you to put 950-1200
or 70 /U90-100 losi
use original spring
tom1974 is offline
