Radiosistemi Crono Dual Evo 1/8 Buggy >
Old 11-20-2012, 10:41 PM
Trader Rating: 40 (100%+)
Default Radiosistemi Crono Dual Evo 1/8 Buggy
Since the Radiosistemi will now be available to everyone here in the States, Canada and Mexico, I figured it was time for it's own thread.
RS Crono Dual Evo 1/8th Buggy:
Some of the Features:
  • Made in Italy
  • 43/13 & 40/12 Overdrive Gearing
  • Machined Spiral Cut Diff Gears
  • Aluminum Center CVA Shafts
  • Two-piece Hardcoat Aluminum & Titanium Pivotballs
  • Universals
  • Lightened & Hardened Differential Outdrives
  • 16mm Big Bore Shocks w/ Delrin Tapered Pistons & Delrin O-Ring Bushings
  • Flex Braces Front & Rear
  • Lightweight Wheel Hexes & Nuts
  • Aluminum Shock Standoffs & Delrin Bushings
  • Aluminum Steering Posts
  • Aluminum Tie Rod Balls
  • Aluminum Wing Washers & Wing Braces
  • Aluminum Upper Arm Hanger
  • 3-Shoe Adjustable Clutch (1 Carbon + 2 Aluminum)
BrakeTurnAccelerate is offline
Old 11-20-2012, 11:20 PM
I so wanted to be the first to get one.
When is yours going to be driveable?
RePeTe is offline
Old 11-20-2012, 11:44 PM
1evo RRR Driver's Avatar
Default new buggy.......
Anybody notice the length of the rear shock bodies vs the length of the shaft?? Looks like no travel........
1evo RRR Driver is offline
Old 11-21-2012, 01:42 AM
Picture is a bit deceiving due to the spring perch. Admittedly the body is a bit longer than normal, which allows the piston to stay fully in the shock body. There's plenty of up-travel (same as every other buggy), and there's more down-travel than any other buggy I've owned. Shock shaft is 65mm, Durango/HB/Losi/Etc that use the shorter style shocks are all around 60-62mm, and the long Mugen/S-Workz shocks are 72mm.
Old 11-21-2012, 04:47 AM
Rcrenew's Avatar
Wow, I used to run a Crono about 15 years ago. cool to see them back
Rcrenew is offline
Old 11-21-2012, 11:13 AM
Do you have anymore detail pictures?
thorns is offline
Old 11-21-2012, 01:55 PM
Looks like a Crono RS7!Great to see Radiosistemi is still alive
30Tooth is offline
Old 11-21-2012, 02:37 PM
Yep, I need upload them, but I'll post some more this evening.
Old 11-21-2012, 04:04 PM
Take your time, HURRY UP, and can we buy direct on that black friday special deals? I have some funds burning a hole in my pocket.
RAlmeida is offline
Old 11-21-2012, 04:28 PM
Old 11-21-2012, 04:33 PM
Yes, I should have the webcart up and running tonight, was waiting on USPS Webtools. Everything will be on preorder. They'll arrive in Early Dec. with plenty of time before the Holidays.
Black Friday deal will be sweeeeet.
Old 11-22-2012, 02:20 PM
Black Friday Pre-Order Special.
RS Crono Dual Evo $569.95, FREE SHIPPING (USA)
Old 11-22-2012, 04:39 PM
Decided to knock another $30 off the BF special.
These are lower than I probably should be selling them for.
HAPPY THANKSGIVING ALL!
Old 11-22-2012, 04:48 PM
Also a good price on the OS speed.
RePeTe is offline
Old 11-22-2012, 05:53 PM
D8
D8's Avatar
It looks somewhat different than the proto buggy that Riccardo Rabitti has been running..
D8 is offline
