Losi Gen III Tray
Hey guys just upgraded to the Gen III tray and im am also upgrading to LiFe aslo.
Which life battery would run in this that will fit nicely or a little dremelling?? I got told the 1700 mAh but is there any otheres else where that are around 1500 mAh plus and a smaller size then 54 x 31 x 31??? |
My set up, reedy 1700 mah life pack.
http://i28.photobucket.com/albums/c2...i/0792a041.jpg I dremeled the ribs down a little but not lower then the screw. http://i28.photobucket.com/albums/c2...i/c2a54272.jpg This is how the botom of the battery looks with no foam after 6 months of racing. Not bad either. http://i28.photobucket.com/albums/c2...i/f8046f9c.jpg Charge lead on the outside. http://i28.photobucket.com/albums/c2...i/d8cff28a.jpg |
I run a lipo from exceed, and I NEVER had to drimmel anything. the secret with the radio tray is that the battery cover does NOT snap DOWN it SLIDES into place, just place it over the battery and make sure the screw holes are under the throttle linkage, then you should be able to slide it to the rear and get the tab in place with the screw holes lining up. When I first got it I tried to lock the tab first then get the screw holes to line up this is NOT how it is done, it takes me like 3 seconds to get it down doing it the slide way. Hope this helps
i use this on and with the lipo battery cover.
http://www.ebay.com/itm/Hobbico-LiFe...ht_4199wt_1059 that is the same guy I got mine from fast shipping. Jason |
I use this one. Its a Dynamite Life pack 1300 mah and it last 3 quals and a 20 min main. I started a thread a few months ago and was recommended this pack and it works great.
http://www.dynamiterc.com/Products/D...ProdID=DYN1413 I had the reedy 1700 and it works good too but you cant use the flat receiver top. You can use the flat top with the dynamite pack though. |
I have the protek RC life battery it wouldnt fit just fell short but with a bit of pressure pushing down on the lid and all screwed in well,
Well the battery wont ever move around inside there because its a tight fit. |
