Spur gears that fit the rc8/b/2 HELP PLEASE
hi all I'm looking for a spur that's 43t or below that fits the rc8/b/2, I'm aware of the rrp 43t spur but will any other manufacturers spurs fit? there must be one or two that share the same dimensions? Lower teeth number the better as I'm trying to setup for speed runs. Have the xo1 34t pinion already.
Thanks all....
I know this is a nitro forum but if u don't ask u don't get :-)
Thanks all....
N e 1?
It looks like you found it already, RR.
I hear kyosho will work with a little dremel work on the screw holes.
Or you can look around here to try to find something that will work.
https://sdp-si.com/eStore/
AE makes a 44
AE makes a 44
