Sweep Buggy Tyres >
Sweep Buggy Tyres
Sweep Buggy Tyres
Old 07-18-2012, 11:28 AM
Default Sweep Buggy Tyres
Hi guys,
Would you recommend using Sweep tires, I normally use Proline.. Also which type and compound would you recommend?
Kaano97 is offline
Old 07-18-2012, 11:40 AM
larlev's Avatar
Well I a little biased with my opinion but I feel Sweep tires are the best out there. They have great wear and the foams are very durable and hold their shape. I've ran a full weekend on a set and still had great traction on the last lap of the event.
The compounds are Silver=ultrasoft, Blue=soft, and Red=medium
If your in a hot climate during summer run Blues or Reds, Mild temps you can run Silvers.
larlev is offline
Old 07-18-2012, 01:09 PM
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
I have had good success with silver square armors in the past.
yzracer758 is offline
Old 07-18-2012, 06:54 PM
Trader Rating: 29 (100%+)
What are the conditions of your tracks you race on? Sweep tires have made me a better driver and racer so far this year. I can really feel the tire compared to the other brands.
madhammer is offline
Old 07-18-2012, 07:36 PM
rcgeezer's Avatar
We run Sweep tires on our buggy and truggy, and they work flawlessly!! You'll find the rubber compound to be a bit different than other brands, but the tire wear is amazing. There are many tread patterns offered for the buggy...give'em a try, you won't be disappointed!
rcgeezer is offline
Old 07-18-2012, 08:06 PM
The tires are really good. they have good traction and great wear. They compete with some of the best.
Chadaman95 is offline
Old 07-18-2012, 08:29 PM
Trader Rating: 36 (100%+)
I think, if you're coming from PL to Sweep, you'll be very happy.
NitroOB4You is offline
Old 07-19-2012, 03:15 AM
My local track is dusty and it doesn't have much grip. Would you recommend the exagon tyre?
Kaano97 is offline
Old 07-19-2012, 05:29 AM
Square armour and micro contact are my favourites.
rossham46 is offline
Old 07-19-2012, 09:31 AM
THE PHILLY JYNX's Avatar
Battle Stars are all I use in buggy for dry dusty condictions. Great forward bite and are consistant over an entire main. The exagons have great tread life but i find the pins are to tall and roll over to much (in buggy) hooking ruts. So for me if its dusty with next to no moister in/on the track its silver battle stars. if its dusty and the track has moister then its square armors.
THE PHILLY JYNX is offline
Old 07-19-2012, 09:38 AM
SUPERLOOPER's Avatar
Is it hard packed or loose dirt? Sandy or clay?
SUPERLOOPER is offline
Old 07-19-2012, 02:20 PM
Its loose and sandy..
Kaano97 is offline
Old 07-19-2012, 02:29 PM
jmaxey51's Avatar
when in doubt go with square armor. pretty much the only tire i run. also i keep exagons and battle star on hand just in case. micro contacts are good to have but work best on hard pack IMO. i always run blue unless its winter. also use some reds.
jmaxey51 is offline
Old 07-19-2012, 04:31 PM
How about double action compare to square amour ? For dusty loose clay track. Any thought ?
Hartw is offline
Old 07-20-2012, 05:51 AM
+1. Most folks are running the new closed cell foam also. The stock foams are good also. Closed cell will give the tire more side bite.
Brian
