TLR TEN-SCT Nitro 4WD RTR >
Like Tree1Likes
Old 08-07-2014, 07:28 AM
  #661
jmoose1's Avatar
Originally Posted by o.s. power View Post
so i got bored tonight
Very cool........report back if there is a noticable difference.
jmoose1 is offline
Old 12-31-2015, 05:03 PM
  #662
bumping this up top just because i love this truck!
copyright is offline
Old 03-09-2017, 11:48 AM
  #663
I have two of them..NOT sure why? LOSI discontinues the parts so they are kind of useless. I'll probably have a bonfire and burn them. Go LOSI blah blah blah
NitroJunky721 is offline
Old 05-08-2017, 07:25 AM
  #664
Trader Rating: 120 (100%+)
Yeah, however, it looks like the nitro sct and the scte share a lot of the same parts.
aznitronut likes this.
8ight-t_sbs is offline
Old 05-17-2017, 12:53 PM
  #665
Got the trucks yesterday. Here is what I have done so far.
Removed
- Ross starter System (it looks identical to an old EZ Start)
- Losi 3.4
Installed
- Losi 4 shoe nitro clutch on the .18tz and dropped it in with no issues.
- Changed out the spur gear to an 8ight-e 43 tooth so that the mod 1 clutch bell and spur gear will work. Only had to widen the center hole of the 8e spur gear a little to make it fit. The screw holes lined up perfectly.
- Ground down the spur gear cover so it didn't rub on the clutch bell.
Going to give this set up a try to see how it works. Currently geared 13/43. I am guessing I'll need a higher tooth clutch bell in the future.
Old 12-31-2017, 12:43 PM
  #666
Ran a few tanks this morning and she runs great!! Going to run a few more this afternoon.
Using a Losi 8ight flywheel and clutch. 16/45 on gearing (8ight e plastic spur)
The Reedy 2100mah rx Pack is a direct drop in and works great!
Running it in a parking lot around some truggy tires. Canít wait to run it at a track!
Old 01-06-2019, 11:48 AM
  #667
what are the part numbers for the clutch Bell and spur gear that you used dot-dot. Also did you use the lowered engine mounts... was it a lot of modification to make this engine fit
Pbabyyy1 is offline
