Setup Boards
Old 06-27-2012, 11:55 AM
JoePit's Avatar
Trader Rating: 15 (100%+)
Default Setup Boards
What are some of you guys using for 1/8 scale. I bought a 24X24 piece of plexxi from Home Depot but it seems to have to much flex. Let's see/hear what you have, and where did you buy it. I'm trying to avoid spending 50 bux on a piece of plastic.
JoePit is offline
Old 06-27-2012, 12:05 PM
RCmayor's Avatar
Plastic isn't gonna be solid until it gets to about half inch. Be careful on what type of plastic because they aren't all fuel proof. Lexan is, but I don't think you can get really thick lexan.
Carbon fiber that big is solid at about 6mm, that is pricey though.
Best bet might be 1/4" tempered glass, but that is fragile. Just be careful with it and sand/bevel the edges.
Next up would be a Hudy board. They are decent priced and wear good. Pretty heavy also though.
I have seen guys use Aluminum panels, top and bottom is solid but the innards are corrugated. it is stiff and light.
You might be able to get a sink cutout from a granite countertop company. That would be really heavy but for something sitting in your garage it wouldn't be bad.
RCmayor is offline
Old 06-27-2012, 12:16 PM
Frank L's Avatar
Trader Rating: 148 (100%+)
I use the hudy truggy board at the track and it gets the job done. At home I have a piece of 28x28 alum. It is very heavy but accommodates truggys nicely. 24x24 works but that extra 4" is nice when setting up a truck.
Frank L is offline
Old 06-27-2012, 12:20 PM
JoePit's Avatar
Looks like the Hudy might be the clear no brainer if you want something consistent. My Hudy setup station is arriving today so I wanted something other than that ugly scratched up piece of plastic I'm carrying around. Thousands have been spent so i guess another $50 bux won't kill me. I keep telling my fiance I pretty much have everything I need.
JoePit is offline
Old 06-27-2012, 12:26 PM
I use 1/2 plexiglass... It does not flex...
token is offline
Old 06-27-2012, 12:50 PM
Zerodefect's Avatar
I use a glass cutting board from Walmart or Koles.
Zerodefect is offline
Old 06-27-2012, 01:11 PM
"Smiley"'s Avatar
Trader Rating: 171 (97%+)
I get all of mine from www.estreetplastics.com
"Smiley" is offline
Old 06-27-2012, 01:21 PM
Z Crazy's Avatar
Home Depot - White Melamine Board
Similar, if not the same thing they use for HUDY boards.
$17.00 is enough to cut two Truggy boards and maybe a 1/10 size board.
Z Crazy is offline
Old 06-27-2012, 01:52 PM
Z Crazy's Avatar
Home Depot Melamine Board, same or similar stuff to what Hudy uses.
I suggest the 3/4 thickness. Its enough to make a few boards for less than $20.
Z Crazy is offline
Old 06-27-2012, 02:10 PM
beidle99's Avatar
I have started making some out of pvc trim board thats 5/8" thick. I make them 20 x 24. Little larger then the Hudy truggy board. I even put a 1 1/4" hole at the top, so that its easy to carry
The pvc trim board has proven to be fuel resistant, I havn't left fuel sitting on it very long to prove if its fuel proof. The little bit I have spilled and wiped off hasn't left any marks or started destroying it yet.
I keep it flat when stored since almost any product could warp if left on edge for long. I do know that if it does warp, leaving it out in the sun on a flat surface will soften it up enough that it will go back into shape. I have made a few for friends and just got enough stock to sell them local for $30 a piece. Shipping to AZ would be the only draw back. Not even sure how much it would cost to ship these out, not to mention I only have enough material to make 12.
That being said you could check out a local building supply company to check on pricing or maybe get a broken or damaged piece you could get for cheap.
I also made a set of cornhole boards out of this stuff that I never have to store in the shed since its weather proof.
beidle99 is offline
Old 06-27-2012, 03:46 PM
Roelof's Avatar
If you want something light, strong and straight get a piece of airplane aluminium, a 2 layer plate with in between a hollow hex profile.
Roelof is offline
Old 06-27-2012, 03:52 PM
JoePit's Avatar
Can you post a pic? I might be interested i one of these.
JoePit is offline
Old 06-27-2012, 04:15 PM
dakilo's Avatar
Trader Rating: 53 (100%+)
+1for about 10-12 bux your good to go.
dakilo is offline
Old 06-27-2012, 04:31 PM
R/C Tech Elite Member
Dustin's Avatar
Trader Rating: 118 (100%+)
Right at 20.00 for 24x 48 melamine and roll of edging, can make 3 boards out of that, here is 1 I made today
Dustin is offline
Old 06-27-2012, 04:33 PM
Z Crazy's Avatar
Dustin,
I've been painting my edges, what were you using for them?
Z Crazy is offline
