RC Crew Chief
Old 02-08-2015, 09:32 AM
  #16
Butler02's Avatar
I just downloaded the demo and set up a model for my Spec-R R2. Took me forever to get the measurements right. Once I had it sorted out I messed with the setup changes and the dynamic part. It was interesting to watch how at certain points in a corner I could see where I was getting snap oversteer, and the results of the changes I wanted to make to correct it. This program is pretty sweet.
Unfortunately I think the free trial has some bugs. I kept getting all sorts of errors when trying to save a chassis or when recalling it. I even lost the measurements for the entire model. I've been told the full version doesn't have any hiccups like that and runs flawlessly. After seeing what this program can do, I'm seriously considering buying it. Very very useful tool!!!
Butler02 is offline
Old 02-09-2015, 02:57 PM
  #17
BobW's Avatar
Originally Posted by masher81 View Post
I am racing a NB48.
Sorry for the slow reply. The real world caught up with me.
I don't have a model for the NB48 but there is one for the EB48.2. That would be a good starting point. The image below shows the numbers for that model.
That model would certainly be a good starting for a NB48 model. Suspension should be the same or very similar. The total weight and CG location would be different and need to be adjusted.
File Type: pdf
BobW is offline
Old 02-09-2015, 03:10 PM
  #18
BobW's Avatar
Should probably move this discussion in the on-road thread. Nitro offroad guys probably don't want to listen to this. Any way the trial version and full version are the same so you probably did something wrong. Can easily happen when you edit an existing model instead of creating a new one. I can certainly have a look at your model if you want to email it to me. Just export it from the "Car Manager" and email it to [email protected]
BobW is offline
Old 02-09-2015, 09:31 PM
  #19
Butler02's Avatar
Oops!! Sorry! I didn't see which section this thread was in, just that it was about RC Crew Chief. If I remember, I'll email you my file in the morning. Thanks!
Butler02 is offline
Old 02-10-2015, 07:14 AM
  #20
vwduud's Avatar
Trader Rating: 48 (100%+)
I am racing a NB48.
Masher,
Message me with your email address. I'll send you the NB-48 car file for RC Crew Chief.
Bob, I'll send you a copy as well for your download section on the website.
Jim
vwduud is offline
Old 02-10-2015, 08:00 AM
  #21
Originally Posted by vwduud View Post
Masher,
Jim
Vwduud can you send me a copy as well, I would really appreciate it. Pm send.
jvcabezas is offline
Old 02-11-2015, 07:08 PM
  #22
BobW's Avatar
Tekno NB-48 model is on the website. Nitro model section is at the bottom of the page.
http://rccrewchief.wrightdesign.ca/OffRoadDownload.aspx
BobW is offline
Old 07-09-2016, 03:00 PM
  #23
BobW's Avatar
It's taken a long time coming and took a staggering amount of effort but the just released RC3 Version 4.2 now has damping simulation included. Now you can see how oil viscosity, piston holes, temperature, shock position.... affects chassis response. This is one of the most misunderstood and difficult to comprehend subjects in setup. Now there is something that can turn on that light.
Big thanks to icecyc1 for sharing his Shock Dyno test data with me. Real confidence booster to know the model agrees with real world testing.
Check out the Youtube video for a brief intro.
BobW is offline
Old 07-09-2016, 11:44 PM
  #24
Can you up load the rc8b3 nitro model for me.
Kakenballs is offline
Old 07-10-2016, 02:56 AM
  #25
BobW's Avatar
The only way I can create models is if I can borrow vehicles from local racer's or alternately other users create models and donate them to the online library. Unfortunately it's unlikely I will be able to get my hands on a RC8b3 certainly not for a while.
The good news is if you have digital calipers the program is setup so you can create your own models. You would start with one of the existing 8th scale buggy models as a base, measure your vehicle and then alter the dimensions to suit. Just takes a little time and some disassembly.If you Open the “Chassis Manager” and click on one of the Measurement Sheet buttons you can see what information is required. Lots of other users have successfully built models. There is a series of Videos on the website that goes through the process of measuring and creating a model for a AE B44.2. I can offer support via email to help you through the process if you decide to give it a try.
BobW is offline
Old 07-13-2016, 03:21 PM
  #26
Arctic RC's Avatar
This program looks promising!
Finally we will get out cars dailed without a lot of try and error at the track. We can make an educated assumption and start to tweak the car in the right place and expect to see some improvements in our setup. Of course we still need to know what we want from the car but it is more efficent when you can start to wrench on the right things instead of wrenching and see that you made a correction in the wrong way.
It would be nice to be able to run this on a tablet or similar, easier to bringa to the track.
Arctic RC is offline
Old 07-13-2016, 05:28 PM
  #27
BobW's Avatar
Runs great on windows tablets. I have a cheap 8" tablet that I run it on at the track.
BobW is offline
Old 07-17-2016, 01:02 PM
  #28
Bob running a split piston. A 1.2-1.3 8 hole would I enter that as a 1.25 ?
rbrownsr is offline
Old 07-17-2016, 05:43 PM
  #29
BobW's Avatar
So if the piston hole configuration is 4x1.2 plus 4x1.3 then yes you want to get the total area the same so 8 x 1.25 would be the right way to go.
BobW is offline
Old 07-31-2016, 02:21 PM
  #30
BobW's Avatar
Another update has been released with a few bug fixes and some small improvements. Doesn't seem to matter how much testing that's done there are always a few bugs that sneak through.
All 92 models on the website have also been updated to include generic steering and shock/damper models as a minimum. This should make it easier to explore the new features.
Also uploaded a couple new buggy models, JQ White Edition LV and Intech ER-14. Thanks to Markus and Swith Racing for contributing. Lastly three new 13.5T Brushless motor models have been added, Trinity 24K, Fantom FR-1 T and Fantom FR-1 M
BobW is offline
