Losi Ten-T To a 810 1/8th Buggy >
Old 06-09-2012, 04:25 PM
rcking112's Avatar
Trader Rating: 26 (96%+)
Default Losi Ten-T To a 810 1/8th Buggy
I was wondering if anyone has done this, Im looking to do something with my Ten-t and I want an 1/8th scale buggy, The 810 is close and im looking to do it, ive heard people have done this.
I would need a parts list that it would take to do the conversion, Thanks for any help
rcking112 is offline
Old 06-10-2012, 08:49 PM
Zao18's Avatar
Pretty easy conversion, I did it to mine. Here's what you need:
1. 810 wheel hexes (http://losi.com/Products/Features.aspx?ProdId=LOSB3499)
2. 810 wheel nuts (http://losi.com/Products/Features.aspx?ProdId=LOSB3498)
3. 5/40 x 1/8 set screws (http://www.losi.com/Products/Feature...rodId=LOSA6299). This one is missing on the 810 parts explosion sheet, but I assure you, they fit. They lock the wheel hexes onto the driveshaft.
4. 810 clear body (http://losi.com/Products/Default.aspx?ProdID=LOSB8036), or you could just get the pre-painted one (http://losi.com/Products/Features.aspx?ProdId=LOSB8035)
5. Body mounts (http://losi.com/Products/Default.aspx?ProdID=LOSB2505). Only comes as body mounts + wing mount. Can't get them separate.
6. 810 wing (http://losi.com/Products/Features.aspx?ProdId=LOSB8155). I guess this is a pretty optional item.
As for the rims/tires, any 1/8 buggy rim/tire with zero offset will fit.
Edit: Forgot to also add the 810 axles (http://www.losi.com/Products/Feature...rodId=LOSB3567).
Zao18 is offline
Old 06-10-2012, 11:58 PM
rcking112's Avatar
Do u need rhe 810 chassis? Or are they the same chassis?
What abour arms? Any different?
Thanks!
Old 06-11-2012, 03:53 AM
SolderGlob's Avatar
Chassis and A-arms are the same. Everything Zao pointed out plus these axles will be all you need.
SolderGlob is offline
Old 06-11-2012, 01:51 PM
Zao18's Avatar
Darnit! Knew I was missing something. Thanks SolderGlob for adding the axles.
Zao18 is offline
Old 12-26-2012, 12:01 PM
Subhuman2178's Avatar
i have a TEN scte that i was debating doing this conversion to but i heard the 810 stopped production recently..... do you guys have any issues with breaking those parts neede for conversion? if not i might go for it
Subhuman2178 is offline
