Kyosho Light blue Springs. What's the spring rate? >
Old 06-04-2012, 08:12 AM
metoo's Avatar
Default Kyosho Light blue Springs. What's the spring rate?
I'm looking for the spring rates of IF250-714 and ISO106-814.
I google searched this board with "light blue" +"spring rate" + kyosho site:http://www.rctech.net/forum and other search methods and criteria on this board, other boards, and the general internet and have not found the answer. If I had the springs in hand, I could come fairly close to getting the information. I prefer to know without having to purchase them first. If you know, please share the wealth. Thanks
metoo is offline
Old 06-04-2012, 08:17 AM
Trader Rating: 53 (100%+)
Kyosho doesn't label the rate. and I don't think anyone on here has sent them to a independent testing lab to confirm whatever rate it may be.
nv529 is offline
Old 06-04-2012, 08:35 AM
Trader Rating: 14 (100%+)
2.65 lbs
o.s. power is offline
Old 06-04-2012, 09:26 AM
metoo's Avatar
All ya need in a scale, a washer larger than the OD of the spring, and some calipers for a very close result. I have all 3, but I don't have the springs.
1) Measure the thickness of the washer.
2) Set the caliper to an inch + the washer thickess and lock it.
3) Place the spring on a scale and put the washer on top of it.
4) Zero the scale.
5) Place the depth-checker-thingy-end thru the washer and spring and push the caliper down until the depth-checker-thingy-end touches the top of the scale.
6) Record the reading.
7) Repeat a few times to check for human error.
Originally Posted by o.s. power View Post
2.65 lbs
Thanks. Where did you get that from? Also is that for both? I know that with Associated for the RC8.2, springs of like color have different rates for front and rear, e.g. silver front = 4.3, silver rear = 3.55.
metoo is offline
Old 06-04-2012, 10:58 AM
does anybody no the spring rates for the dark blue, light blue and light green all fronts fronts?
av4625 is offline
Old 06-04-2012, 11:38 AM
on the rear light blue spring my chart shoes 3.5 lbs as well.
donrod is offline
Old 06-04-2012, 11:39 AM
shoes = shows
donrod is offline
Old 06-04-2012, 01:18 PM
metoo's Avatar
Originally Posted by donrod View Post
on the rear light blue spring my chart shows 3.5 lbs as well.
What chart? Gimme!
metoo is offline
Old 06-04-2012, 01:22 PM
yea wat chart but i said fronts?
av4625 is offline
Old 06-04-2012, 04:23 PM
My bad I show the rear light blue at 3.04 in/lb the ft light blue at 4.50 in/lb. Sorry I dont have a complete chart just those were tested
donrod is offline
Old 06-04-2012, 08:38 PM
metoo's Avatar
Is this a chart from test you personally conducted? Please share the chart. Stop making me beg.
metoo is offline
Old 06-05-2012, 10:50 AM
kman16jr's Avatar
Trader Rating: 56 (100%+)
I say throw them on and love how the car drives after the spring change,I heard the kyosho springs are magic
kman16jr is offline
Old 06-05-2012, 02:19 PM
as I said I dont have a complete chart I only had the blues tested.
donrod is offline
Old 09-26-2013, 07:43 PM
Default Chart
Here is a link to the Kyosho springs:
infernosonly.com/Kyosho_Big_Bore_Shock_Springs_Light_Blue_Short_70_ p/kyoif350-714
SvenNor is offline
Old 09-26-2013, 09:45 PM
moto775 is offline
