New Truggy
New Truggy
Hello everyone,
I am just starting to get into the hobby and was looking to show what ive done so far and ask for any advice.
I received a Losi Ten-T 1/10 Truggy for my first nitro car.
I actually got it as a gift, so I am looking to learn and make my mistakes through growing pains in the truggy before I get into a different car.
After getting it home and reading up on the truggy I broke it in with the following process.
3 tanks idle...
1 tank at 1/4 throttle...
1 tank at 1/2 throttle...
After breaking in the truggy I went ahead and replaced the glow plug just to be safe...
I ran about 10 tanks in the backyard just plain around in the wet dirt after it had rained...
I then pulled it apart and started to clean it...
I put it back together and everything runs great and its an awesome truggy thus far...
As of now I am looking to do some upgrades.
I put in an order today for some parts...
Xtreme Racing Xtreme Brake Disk.
Xtreme Racing package of two brake disks are constructed of blue carbon fiber and replaces stock aluminum brake discs.
Integy Billet Machined Front Lower Arm
Integy Billet Machined Rear Lower Arm
Integy Billet Machined Wing Mount
I was looking for a little info on what regular maintenance should look like. What needs to be oiled, lubed, cleaned, etc.
Any advice on future upgrades or tips for a beginner would be awesome.
Thanks!
3 tanks idle...
Thanks!
i have the same truggy and love it. I havent had mine as dirty as yours . the only thing i've really done was added 17mm wheels.
Stay away from aluminum a arms. Total waste unless u want blind and only doing speed runs. Also I seen urnother thread,Brie spektrum telementry isnterrible and ur heat sensor is terrible. I advise a temp gun and remove the speed and heat gauges. There wrong and alway just make u do circles.
What is blind?
Im confused on what you are talking about in regards to the spektrum system.
I can't really understand what your post says.
I also have a question that I ran into today and just remembered.
The front brake pads that came stock on the Truggy really burnt up quickly.
I have the carbon fiber pads on order, but I noticed something as I ran laps with the front pads needing replacement.
When the Truggy is idle it moves. It no longer sits still at all while idling.
Is this because the idle is set to high, or is the idle dependent on the front brakes to stay stopped?
Idle is to high or throttle linkage is open a little to much. Try adjusting carb gap or idle. Carb gap can be done on radio and idle by tune, sometimes ur engines will idle high lean or if to high idle, also high idle causes temps to go higher from constant rmp being high.
How exactly do you adjust the idle speed on one of these guys?
Yah the R.O.S.S. setup seams to be really cool!
Ok sounds good, thanks for the advice.
Interesting. Wonder why they would put a sensor in that isn't accurate?
I think that the tune needs to be running a bit richer. Im going to take a look at that on my next outing. That might also explain why the truggy is running a bit hot.
