Help please!!
Hi,
i bought a savox sc 0251 (set up as steering servo on an xray 808 2011 buggy) 2 months ago and it never did good on turning to the left side , now when i steer to one side and then leave it free the wheels do not come straight but stay to the side i last turned.? Please anyone help.? |
Originally Posted by luke71933
(Post 10663975)
Hi,
Check settings on your remote there prob not set properly,I had the same prob on my buggy.messed
Around with it now works fine. |
Also check your steering wheel in your transmitter. My wheel wad binding and causing me lots of trouble a lot like that. Always sticking randomly to one side or another. I actually had to use a body reamer and ream out the transmitter shell to free up the steering wheel. That problem drove me nuts! Took apart the whole front end of my mbx6r about three times till I figured that out.
I know i need to set it up but it never gets good i tried lots of different combinations but never gets back to the normal free position the wheels stay on one side, the wheel is not jammed.
i changed the batteries of the remote and everything it seems that when my steering is free(wheels in the middle) it is staying steered to the right i think there is something with the servo saver because from the remote trim i cant get any more.
My friends car had same issues this week. Internal gears took a crap. If your car steers fine on the stand and barely moves when you drop it on the ground it's more than likely your internal gears.
