takes off
takes off
My problem is my sc truck runs off after i start it up could it be the idle is too open..? what could it be?
Pop off the air filter and check your throttle linkage. Turn the radio on and set the throttle trim to zero..hit the brake.. if the slide moves, the linkage needs to be adjusted. The idle gap should generally be around .5mm or so.
Thanks guys I'm gonna check on all the info that was given..touch base with yall in a minute to let yall know what happen...thanks again helpful tips
Yea its still happening just racing...any other suggestions I highly appreciate the help....
If all the above already mentioned check out fine, then you may be too lean on the lsn. Try to richen it up a bit.
