-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   Mounting Werks B5 Pro to Losi 8T (https://www.rctech.net/forum/nitro-off-road/612582-mounting-werks-b5-pro-losi-8t.html)
prowlag 03-25-2012 02:57 PM
I am changing from an Alpha Orange head to a Werks B5 Pro in my Losi 8T and seem to be facing difficulties in getting the Werks to fit correctly. Basically, the carb slide section sits too far forward and rubs/sticks against the centre diff section (plastic plate on top that holds the brake linkages). I have tried to move the engine mounts back as far as possible but still no luck. I am relatively new to this so any help would be greatly appreciated.
SDelaney 03-25-2012 03:10 PM
The best bet is the split center diff mount or you can try grounding off the bump off the top of the plastic diff mount so you can get a straight pull on the carb.
Powered By: vBulletin v3.9.3.6
Content © 2001-2011 RCTech.net
