Stay Tight R/C Screws >
Old 01-21-2012, 01:30 AM
Default Stay Tight R/C Screws
Hello Everyone,
In the next few weeks I will be offering screws that will not require a chemical locking adhesive like loctite. My product is a reusable screw, with a bonded locking element already on the screw which can be removed and reinserted over 20 times while retaining its torque value. This product is far superior to the liquid based locking elements everyone is used to for several reasons.
1) No cure time - Insert and go
2) Reusable
3) No messy liquids
4) Prevents stripping
5) Consistent torque values
6) Mil-Spec Grade application
7) Infinite Shelf Life
8) Withstands up to 270 Degrees
If anyone is intereted in these screws, I'm accepting orders now. Let me know the size you need, quantity, and I will quote you a price. If you are not satisfied, I will give you your money back.
Tim35 is offline
Old 01-21-2012, 01:52 AM
Rsickles's Avatar
Trader Rating: 21 (100%+)
So these are graded screws with a Dri-Loc on them?
Rsickles is offline
Old 01-21-2012, 08:55 AM
Yes, the screws are very high quality screws grade 12.9 which have been tested by other users on this site. They come with a patch locking material which is placed on the screws through a manufacturing process. Compared to loctite, this is a far superior product. You will not be disappointed, the R/C industry doesn't know this product exists and actually predates Loctite by 30+ years!
Tim35 is offline
Old 01-21-2012, 09:02 AM
outtafocus's Avatar
How many times can the screw be removed and reinstalled before this new compound will no longer hold the screw tight?
What is the cost difference per screw vs a normal screw?
outtafocus is offline
Old 01-21-2012, 10:11 AM
A consistent torque can be obtained 20-25 removals. The screw will hold until over 50 removals or more.
The cost for the steel screws run .80 to 1.00 each. The aluminum screws will be in the same cost range also.
Tim35 is offline
Old 01-21-2012, 11:05 AM
motomatt's Avatar
Hello Everyone,
2) Reusable
3) No messy liquids
It doesn't get any better than that folks!
Good luck with your venture Tim
motomatt is offline
Old 01-21-2012, 11:32 AM
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
some pic will be nice are you going to make kit packages like tony screws
bigjayjay1 is offline
Old 01-21-2012, 11:57 AM
Give me about an hour and I'll post some pics. I'm waiting to receive the soon. I do plan to offer kits similar to Tony's screws. I'm starting with the most common sizes first. My biggest problem is not the product but changing the industry mindset from using loctite, threadlocker, etc to a consisten quality product.
Tim35 is offline
Old 01-21-2012, 12:27 PM
Default Screw PIC
Here is a pic of the screws with the blue patch...no this is not loctite but a powder which is bonded to the screws.
Attached Thumbnails Stay Tight R/C Screws-screws.jpg
Tim35 is offline
Old 01-21-2012, 02:10 PM
I hope the screws have good quality Hex,s, at $1.00 a screw you would not want one to strip.
rcspeedfreak is offline
Old 01-21-2012, 02:16 PM
The screw grades are 12.9 and are great screws. No failures in the past.
Tim35 is offline
Old 01-21-2012, 06:19 PM
hyder's Avatar
Do u have any manufacturing certificate for the screws? I've dealt with M24 G8.8 bolts and they broke when my men hammer tightened.
hyder is offline
Old 01-21-2012, 06:40 PM
Trader Rating: 25 (100%+)
I've used this type of screw before in a kit build. They work very well.
They will have a somewhat limited appliation in R/C kit builds, as you would want these (or loctite on screws) only on metal to metal connections...so you wouldn't want a full kit of this type...it'd need to be a mix.
Also will be killer for clutch bell screws.
lknracer is offline
Old 01-21-2012, 07:10 PM
What size and type of screws will I need for the clutch bell screws? I'll add those in next week for processing.
Tim35 is offline
Old 01-21-2012, 07:15 PM
For_the_win's Avatar
Loctie turns into a power after drying for a while.
For_the_win is offline
