Losi 8ight 2.0 - what to do before competitive racing?
#16
#19
Another rx battery option to investigate would be the LiFe battery. Long runtime and lower weight compared to the NiMH batteries, but not the risks of LiPo and no need for a regulator.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAAGM
#23
The buggy does good with 2 composite and 2 alum. Personally I liked all king headz alum 6065 with 2 blk and 2 green springs. If you need a little more bottom snap then go to 2 green and 2 gold shoes. I thought the composite shoes wore out way to fast for my liking. The 6065 is a little softer so it takes some of the harshness away that the 7075 shoes have. But the harder 7075 shoes will last a little bit longer.
#24
For clutch I really liked the Comp alum set-up but I had real bad luck with the shoes Breaking on me. Thankfully there's a Company called Buku who are actually filling that need with a Buku style comp shoe. I'll be testing them out this spring for sure and hopefully i can go back to the losi set-up Minus the weak Stock Comp shoes.
#25
#26
Hi,
I'll take 7950 for both throttle and stearing.
I also would like to have an alloy servo arm.
What servo arm should I take for Hitec? LOSA99031 or LOSA99032?
Greg
Greg
#28
Hi,
I will run as much as I can but...mine biggest problem is the availabilty of parts.
We really don't have much things "in stock" for Losi in Poland.
Most things I have to buy on ebay. A lot of them from U.S. so this takes time to ship and then custom clearance...
I'm lucky enough to be in a position which allows me to get all those spares and hop-ups just in case or waiting for time to put them on.
Greg
Greg
#29
#30
