Xray XB9
#2344
Hi, What are the code (parts numbres) of the 2 and 3 stripe spirng?
and where can I find them?
Thanks in advance
Thanks in advance
#2347
However, I think the preferred Serpent pistons are these tapered/conical machined versions which are available in 6, 8 and 10-hole and typically installed with the tapered side facing down.
#2349
When I talked to Mike, he was saying it was going to start this Thursday. They are rebuilding the inside track at the same time so they are going to split the tractor between the two tracks. I think they have it from Thursday AM to Monday. From what he said, the outdoor track is going to keep the same lanes, but most of the jumps will change. The ones that don't change will get re-faced. Should be good!
#2351
shock piston diameters
This is how a few of the shock pistons measure up that work in the XB9.
I've run the XRAY and the Serpent pistons but I am just now building a set of shocks with the Kyosho 1.3 x 8 tapered pistons.
XRAY XB9 shock pistons diameter is 15.80mm - just a little too loose IMO
Serpent 8-hole tapered diameter is 15.95mm - just a little too tight IMO
Kyosho 8-hole tapered diameter is 15.85mm - just about right??... I hope
#2354
I tried the Kyosho, they are good too but I still prefer the Serpent
