Tire Assembly Product
I use the old ofna one, I really works fine
I use that one too and it's by far the BEST tire gluer I've EVER used. Very much worth the money. Once you use it one time you will be hooked. It pulls the bead down perfect EVERY single time and is adjustable for different thicknesses of tires and wheels.
I just glued up over 140 tires with mine in the last couple weeks. Still working perfect......
It's sold by Absolutehobbyz as well:
http://www.absolutehobbyz.com/produc...oducts_id=4072
I use this.
http://www3.towerhobbies.com/cgi-bin...P?I=LXKAZ4&P=8
Its works awesome. Better then factory premounts every time!
can't you make one out of plywood or sheet metal?
I use this.
