Team Associated RC8.2 Factory Team Kit is coming
#9136
Here is a pic, it looks like it is just bolted on but I have been told it wasn't an easy job, loads of time went in to getting it work but his consistency and lap times have improved massively.
Overall he is extremely happy with the result and hoping when he gets his hands on the AE new buggy it will be even better than this hybrid.
#9137
Fellas quick question. For those who can remember. Can you fit a Kyosho tki body on a RC8.2? Is it almost a direct bolt on or not?
#9138
M2C RACING 8.2 BUGGY CHASSIS
M2C RACING is pleased to announce the release of our 8.2 buggy chassis.
made with 7075 aircraft aluminum and anodized clear.
this model has the replaceable steel skid plates front and rear that are
flush mounted to chassis so as not upset the car during landings.
We have been testing this model for a few months now and the drivers
Brandon Melton and Blake Boggs report that the chassis handles very
well.
Blake Boggs was Able to put it in the Amain at the Physco Nitro blast
this past week end.
Since the new car will be out soon, these chassis will be made on a
custom order schedule and will take 2 to 3 week delivery.
part no. m2c 3500
#9139
Just got plates for my rs and need some help, wanting to put 3deg. toe and 2 deg. anti-squat in rear so if i am understanding them right would that be single dot in c plate and single dot in d plate.
#9140
The link to the Avid = http://avidrc.com/downloads/AVID_180...harts_V1.2.pdf
#9141
Any RC8.2 racers out there have a set of the Avid 1mm offset inserts they might be willing to part with? Looking for 1,2 and 3 dot. Updating my stuff after being out of R/C for a few years and would like to get a set but no one seems to have any. Not going to start over with a new B3 since I already have so many parts for the older stuff.
#9142
#9144
Can someone tell me the best shock choice for the RS? I tried looking but this thread is 600 pages lol.
#9145
After saying that, open this thread and use the search this thread button, and type kyosho shocks, you will find a lot of people used the Kyosho shocks, after the Team drivers were using them on their cars! Are they better? do not know, never tried it. Expensive upgrade! But if you buy these and the come with the light blue springs, it might be worth it!
Good luck with your decision!
#9146
What are you guys using for fuel tanks air issues? I've been threw 3 tanks all with the same issue. Swapped a hot bodies tank and it works fine, but I don't have enough clearance between the steering linkages (fuel line oout) and the side of my novarossi pipe and the tank. Either I have the tank move enough to cut off fuel flow OR it melts its self on the pipe.
#9147
Has anyone tried the RC8B3 diffs in the RC8.2? The diff case is carry-over as well as the center spur gear. I want the 44/13 gear ratio for my Nitro car.
#9149
#9150
I just made the swap from the D8T tank.
The B3 tank sits much better on the chassis. It also sits about 15mm more forward then the D8 tank did.
