Team Associated RC8.2 Factory Team Kit is coming >
Like Tree5Likes
Old 02-20-2014, 07:59 AM
  #8776
Jordan Anderson's Avatar
Who's tried the GHEA "Big Dome" shock caps (GHEA2101)?
Do they work well with the Kyosho bladders?
Do the GHEA Delrin shock bushings (GHEA2038) work better and last longer than the stock bushings?
Jordan Anderson is offline
Old 02-20-2014, 04:20 PM
  #8777
coneman's Avatar
i'm using the ghea big dome shock caps.
i found the csi blue bladders the best. 1.3x8 pistons. 47.5f/35r with kyosho light springs. dialed. tried the kyosho and csi black bladders.
as for the ghea delrin shock bushings. yes i did find they last longer. just have to glue them in.
coneman is offline
Old 02-25-2014, 11:57 AM
  #8778
What's everyone using for brakes on the 8.2?
Old 02-25-2014, 12:04 PM
  #8779
TXRC8racer's Avatar
Trader Rating: 19 (100%+)
I am using the box stock brake setup and have been for 2 years and working fine!
TXRC8racer is offline
Old 02-25-2014, 12:27 PM
  #8780
Does everyone use the D8 fuel tank? I heard the stock AE ones are problematic?
Old 02-25-2014, 06:20 PM
  #8781
ABN Hoosier's Avatar
Trader Rating: 20 (100%+)
This might help LINK
ABN Hoosier is offline
Old 02-25-2014, 06:56 PM
  #8782
Thanks!
Old 03-03-2014, 10:48 AM
  #8783
transplantlife's Avatar
Trader Rating: 43 (98%+)
What upgrades are needed for the rc8.2?
transplantlife is offline
Old 03-03-2014, 02:16 PM
  #8784
Default cvd pins
does anybody have a part number for the right cvd pins?unsure which of the mugen ones are right all help appreciated
toofless is offline
Old 03-04-2014, 08:45 AM
  #8785
In a nut shell:
- Fuel tank. See a few threads above where there is a link that shows you how to fit a Hot Bodies D8 tank to the RC8.2. The stock ones tend to have air leaks.
- Kyosho Lt Blue springs and some 8 x 1.3 pistons.
- Avid rear shock tower gives you the "zero" hole mod for the inner camber link. Or just drill the zero hole in a stock tower.
- Avid 1mm offset inserts for the rear can be used to change the role center.
- Make sure your rear hubs have three holes for the camber link and use the inner hole. The new plastic ones have three holes and the aluminum ones have all along.
- the optional FT steering rack is supposed to be good too.
It's a decent car, have fun!
Old 03-04-2014, 02:36 PM
  #8786
In a nut shell:
Jordan Thanks!
Old 03-11-2014, 06:07 PM
  #8787
CnR
CnR's Avatar
Trader Rating: 31 (100%+)
Running Nitro this season for the first time in a very long time.... Can anybody tell me who offers a good break-in Service ?
CnR is offline
Old 03-11-2014, 11:18 PM
  #8788
http://clockworkracingengines.com/co...breakinservice
Old 03-14-2014, 10:43 PM
  #8789
Bealey's Avatar
Hi there, seeking advice on pros and cons for the reciever pack position, front or rear?
Bealey is offline
Old 03-17-2014, 12:18 PM
  #8790
Does anyone run complete K shocks on their car? I have a set and thinking about trying them out. Any mods need for fitment? Thanks!
XMonsterMattX is offline
