Team Associated RC8.2 Factory Team Kit is coming >
Like Tree5Likes
Old 05-14-2013, 01:37 PM
  #8026
I couldn't find a dedicated RC8T thread, so I figured my best bet was to ask here.
1. Are RC8(.2) parts backwards compatible with RC8T? The arms are obviously not, but the rest looks pretty similar?
2. I assume that RC8.2 is basically RC8 with AE upgrades. It would stand to reason that some or all of those upgrades could be installed on RC8T as well. Which would you recommend the most
3. Any spares in particular I should stock up on that are prone to breaking? Mind you, I won't be racing my RC8T, but rather bashing it on 6S.
Thanks.
ignis is offline
Old 05-14-2013, 02:35 PM
  #8027
Tyler Keel's Avatar
Originally Posted by boudin4evr View Post
here is a pioc of how I have mine at the moment
You need to go down 1 hole on the inner camber link, and switch around your hub towers to the opposite direction, they're in the longer position. Then, put them in the inside upper hole. This should give you more rear traction on lower bite conditions. I run on a low/medium bite track that has a dusty top and I run these locations.
Tyler Keel is offline
Old 05-14-2013, 02:51 PM
  #8028
Thanks.
You mean this one.
http://www.rctech.net/forum/nitro-of...-tips-282.html
Chris Reilly is offline
Old 05-14-2013, 06:44 PM
  #8029
jzemaxx's Avatar
should I move my camber link down in tower and in towards tower on hub for loose conditions?
Go down on the hub. Leave the tower untouched.
jzemaxx is offline
Old 05-14-2013, 10:09 PM
  #8030
dirtdog's Avatar
Trader Rating: 20 (100%+)
Looking at the newer setups, it looks like the drivers are not running the ghea lrc plates anymore? Did they discover somthing i missied over the winter? Are people still running lrc in the rear?
dirtdog is offline
Old 05-14-2013, 10:59 PM
  #8031
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
I never did run it, I've just been running the Avid -1mm 3* pills in the D plate.
heavyjeffd is offline
Old 05-15-2013, 06:10 AM
  #8032
dirtdog's Avatar
That achieves the same object though doesn't it. Right now I'm running 2up in c plate 2 down in d plate. With ghea lrc plates. Seem to loose. And I have never liked the 0 hole. What would be a good starting point to work off of with the ghea plates?
dirtdog is offline
Old 05-15-2013, 06:22 AM
  #8033
Tyler Keel's Avatar
In both my cars I run 2 down in the C, and the Avid -1mm 2 dot pill (4* rear toe). Works great for low bite, dusty conditions.
On high bite tracks I will go to the 1 dot in the D plate.
Old 05-15-2013, 07:01 AM
  #8034
carpet Carlos's Avatar
But the ghea gives you a lower roll center 2mm
carpet Carlos is offline
Old 05-15-2013, 08:12 AM
  #8035
Doubled
Old 05-15-2013, 10:18 AM
  #8036
TomErickson's Avatar
Thanks.
Since the new chassis is +3mm in the rear all of the upgrades will work that are not related to the arms. The shock towers would not work since they are designed for the new arm position. Not sure that the rest is much different through.
TomErickson is offline
Old 05-15-2013, 01:21 PM
  #8037
dirtdog's Avatar
So you run the factory c plate?
dirtdog is offline
Old 05-15-2013, 02:56 PM
  #8038
Tyler Keel's Avatar
Yes, I have never tried any of the GHEA plates.
Old 05-15-2013, 05:38 PM
  #8039
vicdamone11's Avatar
I run the avid 1 dot in the d plate too. I think maifield only ran that ghea plate at nats. They're all back on the stock plates now. Which is fine with me I'm done with the disco parts.
vicdamone11 is offline
Old 05-15-2013, 07:16 PM
  #8040
Looking for a set up to start with for a mid grip track that has allot of blown out spots. I will be geting the avid pils and 1.3 x8 pistons and have the zero hole mod and front turnbuckle mod. Just need a good set up to start with have be out of racing for 2 years just need some help thanks
rider500ex is offline
