Team Associated RC8.2 Factory Team Kit is coming >
Like Tree5Likes
Old 07-19-2011, 12:16 PM
  #16
Trader Rating: 53 (100%+)
What makes everyone believe its a mp9 copy has anyone actually measured the suspension geometry to confirm this?
I doubt it.....
nv529 is offline
Old 07-19-2011, 12:40 PM
  #17
chevydc44's Avatar
Trader Rating: 35 (100%+)
I emailed associated they said it should be out around the end of september beginning of october
chevydc44 is offline
Old 07-19-2011, 12:47 PM
  #18
Big Will's Avatar
Originally Posted by jzemaxx View Post
AE should have called it the RC-MP9??? lol
O.M.G your the funniest guy ever to post on this site. RC-MP9 I cant stop laughing.
It's a good thing for AE to continue to improve an excellent platform. That buggy was already better than a lot of others out there and since they have been working on new parts it has just gotten faster and faster.
The AE drivers have been pretty much dominating everyone I.M.O.
Big Will is offline
Old 07-19-2011, 12:52 PM
  #19
nitrofuel's Avatar
But this buggy is Fat...AE Declare 3570g!
nitrofuel is offline
Old 07-19-2011, 01:10 PM
  #20
R/C Tech Elite Member
devnull's Avatar
Trader Rating: 143 (100%+)
Originally Posted by Dlewis4 View Post
lol
Hehe... What servos should I use? LOL!
devnull is offline
Old 07-19-2011, 01:12 PM
  #21
devnull's Avatar
Fat is flavor.
devnull is offline
Old 07-19-2011, 01:18 PM
  #22
jzemaxx's Avatar
Just run it with no motor......save 300 grams easy.
jzemaxx is offline
Old 07-19-2011, 01:25 PM
  #23
mgtmadness2007's Avatar
With the power of todays engines, I do not see this as an issue. Hopefully the alum, Steering knuckles and the rear hubs and lightweight parts will be included. I doubt it though.
mgtmadness2007 is offline
Old 07-19-2011, 01:53 PM
  #24
jzemaxx's Avatar
No that will be the FT version or the CE version that will come out 6 months later and 75 bucks more.
jzemaxx is offline
Old 07-19-2011, 01:59 PM
  #25
Lilja's Avatar
Originally Posted by devnull View Post
Nice...
Do you have an inside scoop, and if you get one early can you show us Forsyth northerners?
New Associated makes me happy....
So thats number 14 this year or what
Lilja is offline
Old 07-19-2011, 02:02 PM
  #26
devnull's Avatar
No sir!
It would be number 1 because of the new name...
See, now I have to get one hehe...
devnull is offline
Old 07-19-2011, 02:13 PM
  #27
token's Avatar
Bout Time...........................................
token is offline
Old 07-19-2011, 02:19 PM
  #28
Trader Rating: 36 (97%+)
Taking what they learned at the 1:8 World Championship in Pattaya Thailand, the engineers at Team Associated took the RC8.2 to another level and in doing so achieved its ultimate racing potential, which has been proven by winning the 2011 1:8 scale off road R.O.A.R National Championship with a 1-2 finish by Ryan Cavalieri and Ryan Maifield.
The RC8.2 Factory Team kit has a long list of new performance parts, making it the best and lightest Associated 1:8 scale buggy to date. The RC8.2 Factory Team starts with the new Factory Team +3mm 7075 hard anodized chassis. The new chassis and side guards add 3mm of length to optimize weight distribution and overall handling.
To further improve handling, the RC8.2 Factory Team kit received newly designed suspension arms featuring centerline shock mounts and an optimized anti-roll bar position. The new suspension arms were designed to work with the Factory Team 5mm 7075 aluminum low-CG shock towers to improve and optimize the suspension geometry, making the RC8.2 Factory Team kit more plush and forgiving in rougher terrain.
The RC8.2 Factory Team kit includes the 16mm "Big Bore" hard-anodized threaded shocks with 4mm titanium nitride coated shafts and revised shock boots to help increase traction and keep the rubber on the ground. The RC8.2 Factory Team kit also proves to be an exceptional value, including many Factory Team parts that were previously only available as separately purchased upgrades.
Take your 1:8 scale buggy game to the next level with the new RC8.2 Factory Team kit, and drive what the winners drive!
RC8.2 Factory Team Kit features:
Factory Team 3mm lengthened 7075 hard-anodized chassis
Newly designed suspension arms feature centerline shock mounts and optimized anti-roll bar position
Factory Team 16mm "Big Bore" hard-anodized threaded shocks with 4mm titanium nitride coated shafts
Factory Team 5mm 7075 aluminum low-CG shock towers with optimized geometry
Factory Team 7075 blue aluminum lower suspension mounts for optimized geometry, light weight and durability
Factory Team 7075 blue aluminum steering knuckles
Factory Team 7075 aluminum axles and center drives
Factory Team 7075 blue aluminum one-piece top plate
Factory Team lightweight spur and ring gears
Factory Team lightweight diff outdrives
Factory Team aluminum steering posts
CVA boots on center and rear drive joints
Heatsink brake rotors front and rear
New low center-of-gravity wing mount
JConcepts Punisher Body and Illuzion wing included
Molded composite radio tray includes optional forward-placement battery box for increased steering
Molded composite front and rear chassis braces
Tough steel-alloy shock standoffs
Factory Team 83mm "big" wheels included
Aluminum clutch shoes
4.30:1 ratio gearboxes for maximum punch
Caster blocks adjust 14, 16, or 18 degrees with molded inserts
3.5mm light CVA drivetrain with full ball bearings
Factory Team shock and differential fluids included
Mud guards
RC8.2 FT Specifications:
Scale: 1:8
Power: Nitro
Length: 473mm
Width: 305mm
Weight: 3167g*
Wheelbase: 323-326mm
Internal Gear Ratio: 4.30:1
Drive: 4WD
*Actual weight will vary depending on the engine, exhaust, electronics and tires used on the finished kit. Tires not included.
#80906 RC8.2 Factory Team Kit
MSRP: $859.99
MAP: $519.99
UPC: 784695 809062
Available: September 2011
ShagNastyEk9 is offline
Old 07-19-2011, 02:30 PM
  #29
Now that is what I am talking about. Saving up for that this fall with new engine, servos, transmitter, tires, lipos,starter box and possibly a truggy.
Old 07-19-2011, 02:31 PM
  #30
devnull's Avatar
Thanks shagnastyek9... Great info!
But now it's too light
devnull is offline
