Kyosho neo race spec troubles
Hi all Im new to nitro buggys
I got a brand new neo race spec with the ke25 engine
Im using 20 weight fuel
i got it to start fairly easy on first go however she was revving high on idle that all 4 wheels would spin.
so I tried to down the idle and subsequently stuffed the needles up I think.
so I have redone the high speed needle 3.5 turns. Im presuming each turn is meant to be 360 turn ? plus one 180 degree turn.
I also played with the idle speed adjuster and the low speed needle.
end result I can not start it no matter what i do I checked glow plug and it lighst up we have fuel ..
some unburnt fuel is coming out of muffler so I removed glo plug and left it ..
any idea where I can re set the needles ? especially the low speed needle there is no value in the manual for it ?
thanks for any help.
