Wheel balancer
Old 05-30-2011, 03:12 PM
emancipation007's Avatar
Default Wheel balancer
Does the wheel balancer work well
emancipation007 is offline
Old 05-30-2011, 06:18 PM
pickle311's Avatar
Trader Rating: 31 (100%+)
A wheel balancer is a must have tool. Makes all the difference in the world.
pickle311 is offline
Old 05-31-2011, 11:44 AM
rangerjkb's Avatar
Trader Rating: 45 (100%+)
Absolutely, you'll feel the difference imeadiately.
rangerjkb is offline
Old 05-31-2011, 11:52 AM
you will see a huge difference in how your ride handles.
morkendi is offline
Old 05-31-2011, 12:07 PM
DiZzYNaTiOn's Avatar
Trader Rating: 25 (100%+)
+1 i cant believe i raced without one, just get some molding clay (the one with oil in it) not the one that dries out.
I have not vibrated any screws out of my car since i got one. And its just so much smoother
DiZzYNaTiOn is offline
Old 05-31-2011, 12:45 PM
JsK
R/C Tech Elite Member
JsK's Avatar
Great tool and you will notice a difference,but there is a learning curve
on how to use one correctly.
This is the one you want
http://www.amainhobbies.com/product_...Wheel-Balancer
The one with bearings have to much drag. You will also need a spare
hub to use on the shaft. And some Lead Tape Weight. You can get the
lead tape at any Golf Pro shop.
JsK is offline
Old 05-31-2011, 01:12 PM
Thats because of the rubber seal and the grease inside, just remove the rubber seal and get rid of the grease with your choice of spray lube, then the drag that came in the stock bearings are gone and then its time to do some precise balancing
Old 05-31-2011, 01:50 PM
Fd2k's Avatar
Im thinking of getting the losi brand myself and it has the bearing... So you mean that one has drag also?
Fd2k is offline
Old 05-31-2011, 01:56 PM
pickle311's Avatar
Bearings by design will have a little more drag at first. As stated, get the grease out and run it dry then the drag will be gone.
I personally use the Dynamite balancer and I replaced the bearings in it with ceramics. I also blew the grease out of them, it will spin for days.
Old 05-31-2011, 03:50 PM
Dynamite balancer here too.
Replaced bearings with metal shielded bearings, no grease and it will spin forever and ever......
McFly505 is offline
Old 05-31-2011, 04:04 PM
Are they a necessity on a truggy or mainly buggy ?
moonie1 is offline
Old 05-31-2011, 04:24 PM
i would say anything that has wheels and races. Bashing, not so much.
Old 05-31-2011, 07:29 PM
pickle311's Avatar
more of a necessity on truggy than buggy due to the larger wheels, but equally important on both
Old 05-31-2011, 08:57 PM
vwduud's Avatar
Trader Rating: 48 (100%+)
My wheel balancer consists of a Losi Eight 2.0 rear hub, axle, bearings and the 17mm hex wheel adapter. Built from worn parts. Cheap. Works as good as the Dynamite balancer I had - if not slightly better.
Holding the hub by hand and gently shaking it (with a wheel installed), helps to allow the heavy part of the wheel to settle.
And as someone mentioned above - use adhesive backed lead swing weight found at golf pro shops.
vwduud is offline
Old 06-01-2011, 12:05 AM
JsK
JsK's Avatar
Yes you can fix or modify the bearings in the Losi,Dynamite,or Hudy
units but why? The DuBro unit works perfectly right from the box.
JsK is offline
