-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   how much tork is needed to run the carb??? (https://www.rctech.net/forum/nitro-off-road/510190-how-much-tork-needed-run-carb.html)
ae-Dan 05-04-2011 11:10 PM
whats the least tork you can get by with on the carb servo???
808gx7r 05-04-2011 11:32 PM
9kg would probably be the min alot would run.
ohh EPiC FAiL 05-04-2011 11:41 PM
really 300+ oz of torque on the carb? maybe for steering, but the carb needs much less. it only really needs good torque to be able to apply brakes!
curacing2 05-05-2011 01:54 AM
Is it for a .21 motor or something smaller?
Anything under 10kg in a 1/8th buggy will not last long with heavy breaking.
go for something like a 15kg ace or something like it.
808gx7r, i thought you got booted off.... or was that just from that thread.
say hi to Juan for me.
craig
808gx7r 05-05-2011 01:56 AM
i use 12kg savox on throttle in buggy and 15kg ace on throttle in truggy
kai888 05-05-2011 02:11 AM
i used a hitec 625mg with 90oz of torque on my brake before and would not recommend it.
not enough power to stop the buggy had a few big accidents :lol:
kgombe 05-05-2011 04:11 AM
when he says 9kg i think he means 9kg-cm which is equal to 125 oz.-in
seanyboyrulz 05-05-2011 04:35 AM
I had NOTHING to do with those accidents :sweat:
token 05-05-2011 06:13 AM
Hitec HS-7980TH - 611oz
This would produce enough stopping power.:nod:
Frank L 05-05-2011 07:41 AM
LMAO
I have used hitec servos with around 150-160oz on the throttle/ brake and it held up ok. But right now I'm running Savox 1268 on lipo in the truggy, 360oz and ko 30100 which runs 260oz in the buggy. If I did it over again I would use the ko 30101 which rates at 436oz. As long as you set your endpoints correct there won't be an issue.
dreaux 05-05-2011 07:42 AM
sorry man buy TORK is just funny.:lol:
I just couldn't resist:D
Taxman 05-05-2011 07:02 PM
So you want to BUY Tork? You cant get someone for spelling if you cant spell either. :lol::lol::lol:
And yes, it's torque.
RAlmeida 05-05-2011 07:20 PM
Brakes are for losers...(J.K.)
omarwashington 05-05-2011 08:32 PM
I wouldn't use less than 150oz, mostly using it for brakes and don't forget the throttle return spring or rubber band.
dashstryk3 05-05-2011 09:26 PM
Im using the Savox sc1258tg for my throttle and brakes. Works pretty well i would say. 12kg of torque and 0.08 sec on 6v.
