MBX6 clutchbell and fuel tank
I have a Mugen MBX6 with a Nova .21 BF mounted on an extreme racing quick change motor mount, a mugen clutch bell and VP pro clutch shoes. I'm not sure what brand my flywheel is because I purchased the buggy used. My issue is the screw that holds the clutch bell on is VERY close to the fuel tank (almost touching). The gears on the clutch are a little forward. My friend is experienced in nitro and helped shim the clutch bell. Is it normal? Thanks
Originally Posted by Resqnu
(Post 8914648)
Wow. Should I plan on purchasing an extra fuel tank? My current one has a rub spot on it now from the clutch bell screw.
(Post 8914691)
Well it is not actually touching while sitting still. But I guess the rub mark on the tank is from some jumping. You can just tell the socket head screw has touched the tank a few times. I didn't know if a different flywheel or other part would move it back slightly.
(Post 8914724)
Many thanks for you help.
could be the type of flywheel,motor mount, clutch bell ect. with after market parts some do not fit well. Also with nova/rb motors they will move slightly forward
Clutch bell is Mugen, Not sure about flywheel, but same color as mugen. Engine mount stated above.
correction, my flywheel is black/dark gray.
it will NOT be the flywheel or clutch or CB because the screw buts up to the crank, nothing to do with any of that stuff. it may have to big of a head on the screw... ill look to see if mine hit the tank, but i dont think it does because that could cause a fire (one of my friends had that problem :lol: )
i would suspect the mount may be causing it to be to close, good indicator is how the clutch bell is shimmed on the crank, if the crank is sticking past the front bearing a good ways the the motor is moved forward slightly and the bell was shimmed back to line up with the spur gear. If the clutch bell gears are forward on the spur gears may need a smaller collet to move it back some.
3 Attachment(s)
Here are a few photos of what I have.
no thats not correct way to shim your clutch bell sorry!
Any recommendations?
