MBX5-T Understeer help
My Mugen truggy has understeer in center and coming off turns. This is an oval track that is smooth, hard packed clay that is dusty. I'm running 5-5-2 (F-C-R). I hadn't had the it that long and was hoping a more experienced Mugen person had an idea so I don't chase it around. I decreased the wing angle and helped a little. The setup is close to right on so the problem has to be diff oil as all else is close to being right on. Any suggestions?
i run the same truck i use 5 7 3 and 40 weight in the front and 35 in the rear still under steers a little but put a little more brake to the rear and pitch it a little:nod:
Originally Posted by ncpene
(Post 8801434)
Try the 2.3 sway up front and if you havent already on the fronthubs where the pivot balls sits you can take a dremel to the plastic hub and remove a little more material to give you more steering. I used to run 7-10-3 for diff oils and my truck was pretty dialed along with a BCE chassis.
You're diffs are too loose. Try 10-10-5 or something.
| All times are GMT -7. It is currently 02:36 PM. |
