Ultrasonic cleaner
Does anyone use an ultrasonic cleaner to clean parts? What type of detergent do you use? I am mainly looking at this to clean diff internals, hingepins and maybe some plastic parts.
I haven't messed with any ultrasonic specific detergents, I use Mean Green from the Dollar General store.
I mix it 50/50 with water and heat it up to 125* or so. Works like magic on just about anything you want to clean. |
Originally Posted by underway
(Post 8724898)
For diff cleaning I use a tea bag strainer (large one), a mason jar, and some M.E.K. (Methyl Ethyl Keytone, $10 or so for a can at WalMart). It pretty much melts the silicone out of the diffs in 30-45 seconds. Take apart your diff...put the pieces in the tea strainer (minus the bearings and O-Rings, close the strainer, and then dip the whole unit into the mason jar half full of M.E.K. and swish it around a bit. Then let it sit for 20 secs or so....swish it again and pull it out. Lay the parts out on a clean paper towel and let them air dry.
It works perfectly every time. It WILL swell the O-Rings though if you leave them in there....and not good for bearings either obviously. |
Originally Posted by MotoGod
(Post 8725236)
simple green works great. i use about 70/30 water to simple green. works well on all parts. i use it for work also on alum and other parts like carbs and rubber parts.
I used Isopropyl alcohol (99,9%) it works great, also for bearings! It's not eating o-rings or somthing like that... very gentle mixture
(Post 8724898)
I use greased lightning w/simple green and filtered water. About a 2:1 ratio on cleaners to water. Greased lightning is available at Lowes and/or Home Depot. Simple and effective. I use the ultrasonic from Harbor Freight, about $25 bucks.
A Better Ultrasonic Cleaner
We use Omegaclean. It removes oil, grease, carbon and other contaminants better than aerosol solvents and hand-cleaning. It's non-toxic and environmentally safe. The buffers protect aluminum finishes and it has silicates that guard against flash rusting. It's about $30/gallon, but worth it. Paste this into your browser: omegasonics.com/industries/power_sports.shtml
I just bought this one and will test it the next time I tear down a buggy: http://cgi.ebay.com/2-0Litre-1-2-Gal...item335cc7fa6c
I hope it is up to the task :) |
anyone tried gun oil?:confused:
Resurrecting the thread. Has anyone used one to clean an Engine in preparation for a rebuild?
Those cleaners will eat up the cast Al block quickly so be careful.
I use a tank of Simple Green in my ultrasonic cleaner for parts. |
Originally Posted by Zerodefect
(Post 14672969)
