what lipo for ofna truggy starter box? >
Old 02-21-2011, 04:16 PM
teeforb's Avatar
Trader Rating: 94 (100%+)
Default what lipo for ofna truggy starter box?
I'm trying to decide on what lipo i should get for the ofna truggy starter box. it will be for a dnx408. How many cells and mah shall I get. I want good power from the starter box and i want it to last a LONG time! Im sure i have space in the starter box, so let me know what's a good size. Also, does it matter the 'C' rating of the lipo? Is 15C lipo packs okay?
thx
teeforb is offline
Old 02-21-2011, 04:26 PM
Trader Rating: 15 (100%+)
As long as it's 4s and at least 20C, you'll be good.
I personally use this: http://www.amainhobbies.com/product_...Ah-Starter-Box
STi oWn$ Jo0 is offline
Old 02-21-2011, 04:43 PM
tgrand's Avatar
I own two of the very same lipo's and they work great.
tgrand is offline
Old 02-21-2011, 04:45 PM
teeforb's Avatar
I have a 5s 4200mah 35c I can turn into a 4s. Shall I do that?
teeforb is offline
Old 02-21-2011, 04:48 PM
boomgagem's Avatar
Trader Rating: 45 (100%+)
No 5S is too much. Use 4S
Also you may want to reinforce those tabs on the spring switch, they will eventually burn off
boomgagem is offline
Old 02-21-2011, 04:49 PM
4s will be fine...
ganymede is offline
Old 02-21-2011, 05:47 PM
That might work just fine, but is it worth the hassle?
Zippy 4S-HK USA $17.47
Turnigy 4S-HK USA $19.11
McFly505 is offline
Old 02-21-2011, 05:51 PM
I am using this:
http://hobbyking.com/hobbyking/store...idProduct=8852
This will work too!
http://hobbyking.com/hobbyking/store...idProduct=8913
ganymede is offline
Old 02-21-2011, 05:56 PM
teeforb's Avatar
I will convert my 5s to 4s.
teeforb is offline
Old 02-21-2011, 05:58 PM
I've been using the Turnigy 2200 20C packs in all my boxes for over a year now.
Never had a bit of trouble, but the extra capacity is always nice, especially when you wind up with the 'community' box....
McFly505 is offline
Old 02-21-2011, 05:59 PM
teeforb's Avatar
I was selling the 5s 4200 for $35. I may as well keep it!
teeforb is offline
Old 02-21-2011, 06:03 PM
"Community Box"? Lol!
Sure loads of newly found "buddies" around you when you bring out that box...
ganymede is offline
Re-post...
To all those with the same setup, you WILL eventually have the same problem.
Theses starter boxes have little, flimsy contacts that, in stock form, handle ALL of the current the motors pull. Not quite the hot setup, IMO.
I had the same issue, so I made new contacts from copper(1/2" copper tube, smashed flat and cut/dremel'd to fit), but I still wasn't happy with the performance I was getting.
So I took it one step further and added a relay to handle the current.
This setup may be overkill, but it ALWAYS works and it's one less thing to worry about come race day.
And yes, it WILL start a Mack truck....
McFly505 is offline
Old 02-21-2011, 06:04 PM
Funny how that works out, isn't it.....
McFly505 is offline
Old 02-21-2011, 06:10 PM
I like the idea of running a relay, is that an automotive relay? Any specific specs?
Any wiring diagram? Thanks!
ganymede is offline
