How to remove a stripped hex screw?
I have a 2.5mm hex screw jammed into my chassis. I don't have a drill to drill out.
What else can I do? Thx guys! |
use a dremel w/ a cutting wheel and cut a straight groove. then use a straight screwdriver
Originally Posted by ncdirtracer
(Post 8603292)
Originally Posted by SuperEk4
(Post 8603248)
What else can I do? Thx guys! Take a soldering iron and heat the screw up with the tip. Use a standard not metric quality hex wrench the next size up from 2.5mm.. It's going to be just a bit bigger and might bite into the screw enough to twist it out. That or you can use a cutting wheel in a standard drill to cut a slot. It's going to take a while and the slot might get wider then you expected but it works. |
I had to do this twice two days ago. On one I cut the slot but I botched it up and the slot got to wide. So I took the dremel grinder and ground the entire head off. This let me "pull "piece one off of peice two.
On my second attempt I ground a perfect slot for a screw driver. Good Luck |
Go to sears and grab an easy out set. You drill the head with one side of the bit and then flip the bit and unscrew the head. Works nearly every time.
Originally Posted by dishsoap
(Post 8604825)
But my the other end is a steering post:( I heard some ppl drill the screw out? |
(Post 8607286)
What equipment do I need?
Forget the screw and try turning the post. Or hold your allen key on an angle while turning the screw. Few different things to try.
(Post 8603293)
Sounds good, but is there anyway I can charge my dremel with a regular charger? I misplace my dremel charger:(
Originally Posted by ben73
(Post 8607788)
It can be done if your charger has a li-ion setting. I've had to do it a couple of times traveling o/s with my race gear.
(Post 8607792)
Found my charger, but still can't remove the screw:(
Works every time.... |
(Post 8607804)
As has been suggested use the dermal cutting wheel and cut a wide slot for a nice big flathead screwdriver. You will the be able to use the screwdriver to crack e screw and remove it.
(Post 8607829)
My cutting wheel is abit too thick, need to buy new cutter blade:(
I've read that you can epoxy the allen key in the screw. Never tried it but it an option.
