JConcepts LPR tires on AKA wheels?
Hi!
I would like to mount Jconcepts low profile tires to some AKA wheels I have using AKA foams... It says the tires need 3.7" wheels and the diameter of mine is 4", will they work or is a quarter of an inch too much? I have 0 zero experience mounting tires so I have no clue if this will work, please let me know ASAP.
Thanks!
Thanks!
They should be fine
Throw them on the wheels and check it out if you don't think it looks right or feel good don't do it but if it seems fine run them.
I dont have them, Im seeing whether to order them or not online! Thanks
They fit perfect I run j concepts double dees with aka foams and rims....
Thanks so much!
Order the J-Concepts 1/2 up rims and you will have no problems with fitment issues. Also be sure to get some mounting bands to keep the bead seated while you glue.
